BT.com
Wishlist
Samsung CLP-415N Colour Laser Printer
Samsung CLP-415N Colour Laser...
£169.76
More than 50 in stock
£169.76
Add to wishlist
Delivery
Standard 1-3 working days
High-speed, high-quality printing
Print quickly and vividly with a Samsung CLP-415 color laser printer. Thanks to Samsung's ReCP technology and polymerized toner, your printouts will be crisper, more vibrant and more vivid than ever before. And, with print speeds of up to 18 pages a minute, you won't have to wait to see the results.
Enjoy quality printouts
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your black & white printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
Polymerised Toner
Our newly developed polymerised toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid detail, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
A higher level of printing performance
Accelerating your business' productivity begins with your printer. With its 18/18 pages per minute output and a first page out time of just 16 seconds the CLP-415N doesn't let you down.
More power, better productivity:
With the power of two cores the device can process your work files simultaneously and therefore with higher speeds. The 256MB memory ensures even heavy printing documents are spooled faster and you don't have to wait long for your print outs. What all this means for you is simple: the CLP-415N is perfect when there's a lot to print and a tight deadline to meet.
An easier user experience for you
Your time is too precious to waste standing around a printer for hours on end. So from operation to support software tools, you're in total control with this easy to use small workgroup printer.
Easy Operating Panel:
With the CLP-415N's 2 line liquid crystal display and intuitive 4 key compass navigation you can control the device's status, browse the menu and access each unique feature with ease.
Easy Solution support
The printer also brings you software support designed to put you in control of delivering ultimate quality printouts easier than ever before.
Easy Eco Driver:
Easy Eco Driver helps you compile digital documents in multiple formats and makes it easy to share them with others - even through social networks.
Your reliable business partner
Thanks to the latest technology and high quality components, you'll find the CLP-415N is as dependable as they come, even during the toughest print jobs.
Anti-jam roller:
We've developed our reliable anti-jam friction roller to minimise the risk of mis-feeds and paper jams. Better still, it allows handling of heavier paperweights, including card, up to 220g/m² from the standard cassette tray.
Dependable under pressure:
You know how important it is for your printer to deliver, particularly during those high-pressure jobs. That's why a 50000 duty cycle means it can handle temporary peak print times with ease.
Cost effective printing with every job
Be in control of your printing cost during the printer's entire time of operation. Low costs per page that keep your running costs low for the time you do business.
High yield, low costs:
Higher yield cartridges means more time between changes, saving you time, while low toner costs means less cost for every page. You'll find the Total Cost of Ownership is slashed.
Less power, less to pay:
There is more money to be saved by reducing power consumption. Our innovative polymerised toner requires a lower fusing temperature, resulting in less energy consumption. And the Dual CPU needs less energy to do its job as well. In fact, with a typical energy consumption of only 1.2kWh - as measured by the Energy Star - the CLP-415N ranks among the top models of its class.
Eco printing:
One push of the ECO button and you can make use of all the smart eco functions that can be indivudually set through the printer driver. Print multiple pages on one sheet, skip blank pages or print in greyscales instead of full colour. It's all there to save you paper, toner, energy and money right away.
Easy colour Management
The Samsung Easy Colour Manager allows you to adjust the colour balance, saturation, brightness or contrast of any image prior to printing. Perfect for matching the exact colours of your company logo every time.
Remote device control
For maximum control, Easy Printer Manager lets you manage all your devices from one location. Check device and toner status, change device settings or set alerts.
Easy toner replacement
Gone are days of fiddly, dirty and time-consuming toner cartridge changes. It's all made easier with a push loading drawer. What's more, the high yield cartridges mean fewer changes.
Samsung CLP-415N - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
16.62 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (Colour)
9600 x 600 dpi
USB, Gigabit LAN
533 MHz
RAM Installed (Max)
256 MB
Language Simulation
PostScript 3, PCL 6C, SPL (Samsung Printer Language), PCL 5Ce, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, glossy paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 images
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Printer Features
Rendering Engine for Clean Page (ReCP) Technology
UNIX, Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.4 - 10.7
42 cm x 42.6 cm x 26.4 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
9600 x 600 dpi
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Printer Features
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
250 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 1 sheet
Output Trays Capacity
100 sheets
Duty Cycle
40000 images
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
Power supply - internal
380 Watt
Power Consumption Stand by / Sleep
50 Watt
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
50 dBA
42 cm
42.6 cm
26.4 cm
16.62 kg
Other bundles
£169.76
Save on TP Link Smart Plug
Save £2.00
£193.73
Accessories
£58.22
£64.05
£64.05
£64.05
£15.24
Scroll to top
