BT.com
Wishlist
Samsung CLP-360 Colour Laser Printer
Delivery
Standard Due date unavailable
True colour and truly compact design
  • Print vividly thanks to new polymerised toner
  • Save space thanks to compact ergonomic design
  • Easily print screen or eco-optimise your output
  • Create and use Easy Colour Manager profiles
The Samsung CLP-360 printer uses minimal space but still prints with maximum color. It uses ReCP technology and polymerized toner to give you vivid true color printing. What's more, its ergonomic design means that it takes up less space, so it fits into your surroundings perfectly. The CLP-360 is also easy to use and efficient, with a one touch eco button to help you save print supplies and energy. You can even print the screen contents instantly with just one click using the one touch print screen button.
Enjoy quality printouts
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
Polymerised toner
Our newly developed polymerised toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colours - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
Ergonomic design
Don't worry about this printer crowding your space.
Its beautiful and compact design makes it a pleasure to share a desk with.
Small size Footprint
With a footprint of just 38.2 x 30.9 cm the CLP-360 is one of the world's smallest colour laser printers.
Ergonomic design
Its ergonomic design with ebony brown and ice grey colour creates a modern and elegant work environments.
Easy to use
Designed for simple and intuitive operation the CLP-360 saves you precious time and effort.
One Touch Eco Button
Just One push of the ECO button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change colour to greyscale or skip blank pages.
One Touch Print Screen Button
Print exactly what you see on the screen with just one click, saving time.
Easy Colour Manager
Create and use your own colour profiles with Samsung's Easy Colour Manager. Match the exact colours of a company logo or simply give your print outs the individual look you want.
Easy Solution support
The printer also brings you software support designed to put you in control of delivering ultimate quality printouts easier than ever before.
Easy Eco Driver
Easy Eco Driver helps you compile digital documents in multiple formats and makes it easy to share them with others - even through social networks.
Samsung CLP-360 - printer - colour - laser
Printer Type
Personal printer - laser - colour
9.85 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 152.4 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 4 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 4 ppm - colour - ANSI A (Letter) (216 x 279 mm)
Max Resolution (Colour)
2400 x 600 dpi
USB
300 MHz
RAM Installed (Max)
32 MB
Language Simulation
SPL (Samsung Printer Language)
Media Type
Labels, plain paper, glossy paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper
Total Media Capacity
150 sheets
Media Handling
150-sheet paper cassette
Monthly Duty Cycle (max)
20000 images
Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4 - 10.7
38.2 cm x 30.9 cm x 21.1 cm
Printer Type
Printer
Print Speed
Wired
USB
2400 x 600 dpi
First Print Out Time B/W
16 sec
First Print Out Time Colour
26 sec
Language Simulation
Media Handling
300 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 152.4 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
150 sheets
Media Feeders
1 x automatic - 150 sheets
Output Trays Capacity
50 sheets
Duty Cycle
20000 images
1 x USB 2.0 - 4 PIN USB Type B
Consumables Included
1 x toner cartridge ( black ) - up to 700 pages , 1 x toner cartridge ( cyan ) - up to 500 pages , 1 x toner cartridge ( magenta ) - up to 500 pages , 1 x toner cartridge ( yellow ) - up to 500 pages
Power supply - internal
290 Watt
Power Consumption Stand by / Sleep
60 Watt
Sound Emission (Operating)
48 dBA
38.2 cm
30.9 cm
21.1 cm
9.85 kg
Scroll to top
