BT.com
Wishlist
Samsung ATIV Tablet P8510 10.1" 32GB WIFI Windows RT
Delivery
Standard Due date unavailable
Choose a tab that offers a complete Windows 8 experience. With the Samsung ATIV Tab, you can use the Windows RT operating system and great Windows 8 apps. You can either use Windows UI mode or PC Desktop Mode, which feels just like using your home PC. Thanks to the preinstalled Microsoft Office suite, you can access and work on all your documents, so you can also be more productive on the go. Meanwhile, Dual Screen multitasking and Charm make it easy for you to get to all the things you need quickly and use them easily.
Samsung Part No:
GT-P8510MSABTU
Operating System Installed
Windows RT
P8510
Processor Clock Speed
1500 Mhz
Processor no of Cores
2
Display Diagonal
256.5 mm (10.1 ")
Display Resolution
1366 x 768 pixels
Internal RAM
2048 MB
Total Storage Capacity
32GB
Bar
Colour of Product
Black Metalic
Ports
USB 2.0 x2 ports, Micro HDMI x1 port
Battery Technology
Lithium-Ion (Li-Ion)
Wireless Lan
Wireless Lan Type
802.11a, 802.11b, 802.11g, 802.11n
Battery Capacity
8200 mAh
3G network access Module
No
Bluetooth
V4.0
Built-in Camera
Yes, 5MP resolution
Second camera
Yes, 1.9MP resolution
GPS Function
Storage Media Type
Flash
Compatible memory
microSD (TransFlash)
Auto Focus
Bulit in Flash
LED
Video recording
Touch sensitive screen
Accelerometer
Built-in speakers
Card reader integrated
Built-in microphone
Ambient light sensor
Gyroscope
W: 265.8 mm, D: 8.9 mm, H: 168.1 mm, 0.57Kg
Scroll to top
