BT.com
Wishlist
Samsung 850 PRO 2TB Basic SATA 6Gb/s 2.5" Solid State Drive
Delivery
Standard 1-3 working days
Samsung's flash memory is fabricated using an excellent 3D V-NAND architecture, which stacks 32 cell layers on top of one another rather than trying to decrease the cells' length and width to fit today's shrinking form factors. The result is higher density and higher performance using a smaller footprint and a breakthrough in overcoming the density limits of conventional planar NAND architecture. The result - enhanced performance, lower power consumption with an up to 1 GB LPDDR2 DRAM cache memory and improved energy-efficiency with the 3-core MEX controller.
Samsung 850 PRO MZ-7KE2T0BW - solid state drive - 2 TB - SATA 6Gb/s
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
2 GB
Hardware Full Disk Encryption (FDE), TRIM support, Garbage Collection technology, DevSleep mode, 3D V-NAND Technology, RAPID mode support, Samsung MHX Controller, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
66 g
10 years warranty
2 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
2 GB
69.85 mm
100 mm
6.8 mm
66 g
Performance
SSD Endurance
300 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
Maximum 4KB Random Write
90000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.3 Watt (read) , 3.4 Watt (write) , 60 mW (idle) , 5 mW (sleep)
Software Included
Samsung Magician Software, Samsung Data Migration
Limited warranty - 10 years
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Scroll to top
