BT.com
Wishlist
Samsung 850 EVO 120GB MZ-N5E120BW SATA 6Gb/s M.2 Solid State Drive
Delivery
Standard Due date unavailable
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience but up to 1.9x faster random write speeds. The 850 EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Samsung 850 EVO MZ-N5E120BW - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
Hardware Encryption
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Hardware Full Disk Encryption (FDE), TRIM support, DevSleep mode, Microsoft eDrive compatible, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MGX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
22.1 mm x 80.3 mm x 1.52 mm
5 years warranty
120 GB
Hardware Encryption
M.2 2280
SATA 6Gb/s
Buffer Size
512 MB
22.1 mm
80.3 mm
1.52 mm
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 500 MBps (write)
Maximum 4KB Random Write
89000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
50 mW (active) , 2.3 Watt (average) , 3.3 Watt (maximum) , 2 mW (sleep)
Software Included
Samsung Magician Software, Samsung Data Migration
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
Scroll to top
