BT.com
Wishlist
Samsung 8-CH 960H 4 Camera 700TVL CCTV Kit 500GB
Delivery
Standard Due date unavailable
This 8-channel DVR package includes 4 weather-resistant, 720 TVL resolution cameras that deliver true daylight color and clear night vision up to 82 ft. The system is easily customized for advanced monitoring and notification options.
Anytime/Anywhere
Samsung's free iPOLis mobile app brings surveillance video right to your iOS or Android tablet or smartphone. To oversee multiple systems in various locations, Samsung's central management software, Smart Viewer, allows video monitoring from all points around the globe on a single screen.
Event/Tampering Alerts
Instant email notifications can be sent when motion or camera tampering is detected and automatically recorded onto the DVR. Guarding your safety, Samsung empowers you to respond instantly to unexpected events, view real-time activity and review stored recordings.
Sharp, Rich Details
The cameras provide up to 720 TVL resolution for clear, vivid image quality. In keeping with this high standard, the DVR records at 960H high resolution onto a 500 GB hard drive to capture all of your important video events.
Wide Angle Coverage
While other cameras constrict your view, Samsung's 72 Wide Angle lens expands your recording coverage without compromising quality.
True Day & Night
Each SDS-P4042 camera utilizes an advanced IR Cut Filter for accurate, vibrant colors and Night Vision mode to capture clear, illuminated footage up to 82 feet in darkness.
Privacy Masking
Privacy Masking allows you to block up to four areas within each camera's field of view. This advantage lets you tailor your monitoring to exclude sensitive areas or conceal irrelevant or personal activity.
Weather-Resistant
Every camera in the SDS-P4042 system has achieved an Ingress Protection Rating of IP66. Rest assured that they have been tested to withstand dust, wind and rain.
Easy Setup/Upgrade
DVR setup is intuitive and simple and can accommodate four additional cameras. Samsung's optional WiFi adapter eliminates the need for network cable connection. This liberates DVR placement away from the router to your most suitable location within WiFi range.
Box Contains
DVR (SDR-4102)
Camera (SDC-7340BC) 4pcs
Remote Control / Battery / Mouse
Adapter / Power Cord
60ft BNC Camera Cable 4pcs
CD (Smart Viewer, User Manual)
Quick Guide / Network Cable
HDMI Cable
SAMSUNG TECHWIN SDS-P4042 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
8 channels
Hard Drive
1 x 500 GB
Camera
4 cameras - outdoor - PAL - night vision
31.5 cm x 22.4 cm x 5.2 cm
1.56 kg
System
DVR + camera(s)
Package Content
4 cameras, DVR, manual, remote control, mouse, power adapter
Camera cable - BNC - 18.3 m - 4 pcs. , Network cable - 1 pcs. , HDMI cable - 1 pcs.
Software Included (Y)
Drivers & Utilities, Samsung Smart Viewer
Security DVR
Video Channels
8
Frame Rate (Playback)
200 fps (PAL)
Frame Rate (Record)
200 fps (PAL)
Image Resolution
720x576 (PAL), 704x576 (PAL), 352x288 (PAL), 704x288 (PAL), 960x576 (PAL)
Compression Format
G.711, H.264
Record Events
Alarm, motion detection, scheduled, event, manual, continuous, tamper detection, time lapse, video loss
Watermark, picture-in-picture (PIP), password protection, e-mail alarm notifications, SmartViewer, Webviewer, Mobile Viewer, 960H Technology
Hard Drive
Quantity Installed
1
500 GB
Serial ATA
Cameras
Quantity
4 cameras
Camera Type
Outdoor
Sensor
CMOS - 1/3" - 976x582
Field Of View
60° (H), 48° (V)
Horizontal Resolution (TV Lines)
700
Scanning System
Interlace
TV System
PAL
Sensitivity (lux)
0
Night Vision
Infrared LEDs
Infrared Distance
25 m
Signal-To-Noise Ratio
46 dB
White Balance
Auto
Gain Control
Auto
Focal Length
3.8 mm
Voltage
DC 12 V
Power Consumption
3 Watt
-10 °C
50 °C
Operating Humidity
20-85%
IP66
Video Input Ports
BNC x 8
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 4
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2, eSATA x 1, serial RS-485 x 1
31.5 cm
22.4 cm
5.2 cm
1.56 kg
Details
Camera: 7.21 cm x 19.24 cm x 6.29 cm - 252 g , DVR: 31.5 cm x 22.4 cm x 5.2 cm - 1.56 kg
Scroll to top
