BT.com
Wishlist
Samsung 512GB 950 PRO Series M.2 NVME PCIE SSD
Delivery
Standard Due date unavailable
If you're a heavy workload professional searching for an SSD with uncompromising power and performance, look no further. The next-generation Samsung 950 PRO delivers exceptional performance for professionals.
This cutting-edge V-NAND-based NVMe SSD supports PCI Express Gen 3 x 4 lanes, providing a higher bandwidth and lower latency to process a massive amount more data than SATA SSDs.
Presented in a compact M.2 form factor, the future-oriented 950 PRO is ideal for professionals using high-end PCs and workstations.
Samsung 950 PRO MZ-V5P512BW - solid state drive - 512 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
512 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
Buffer Size
512 MB
TRIM support, sleep mode, Thermal throttling, Auto Garbage Collection Algorithm, Low Power DDR3 SDRAM Cache, S.M.A.R.T., 256-bit AES, IEEE 1667
22.15 mm x 80.15 mm x 2.38 mm
10 g
5 years warranty
512 GB
Hardware Encryption
256-bit AES
M.2 2280
Buffer Size
512 MB
22.15 mm
80.15 mm
2.38 mm
10 g
Performance
SSD Endurance
400 TB
Internal Data Rate
2500 MBps (read) / 1500 MBps (write)
Maximum 4KB Random Write
110000 IOPS
Maximum 4KB Random Read
300000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
5.7 Watt (average) , 7 Watt (maximum)
Software Included
Samsung Magician Software
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Scroll to top
