BT.com
Wishlist
Samsung 512GB 840 Pro Series SATA 6Gb/s 2.5" Solid State Drive
Delivery
Standard Due date unavailable
The Samsung 840 PRO is a high performance SSD designed for power users. Capable of delivering up to 100,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
  • Capacity: 512GB
  • Sequential Read: 540MB/s
  • Sequential Write: 520MB/s
  • Random Read (QD32, 4KB): 100,000 IOPS
  • Random Write (QD32, 4KB): 90,000 IOPS
  • Random Read (QD1, 4KB): 9,900 IOPS
  • Random Write (QD1, 4KB): 31,000 IOPS
  • Active Power Use: 0.068W (down from 0.24W for 830 Series)
  • Idle Power Use: 0.042W (down from 0.14W for 830 Series)
  • Warranty: 5 Year
Samsung 840 Pro Series MZ-7PD512 - solid state drive - 512 GB - SATA 6Gb/s
Solid state drive - internal
512 GB
Hardware Encryption
2.5" Ultra Slim Line
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hardware Full Disk Encryption (FDE), TRIM support, Garbage Collection technology, Samsung 3-core MDX Controller, Samsung Toggle DDR2 NAND Flash memory, S.M.A.R.T., 256-bit AES
69.85 mm x 100 mm x 7 mm
68 g
5 years warranty
512 GB
Hardware Encryption
SATA 6Gb/s
69.85 mm
100 mm
7 mm
68 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
100000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
Software Included
Drivers & Utilities, Samsung Magician Software, Samsung Smart Migration Software
Linux, Apple MacOS X, Microsoft Windows XP SP2 or later, Microsoft Windows Server 2003 x64 Edition SP2 or later, Microsoft Windows Server 2003 SP2 or later, Microsoft Windows Vista SP1 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits)
TAA Compliant
Limited warranty - 5 years
60 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
Resources
The following resources are available for the Samsung 512GB 840 Pro Series SATA 6Gb/s 2.5" Solid State Drive
Scroll to top
