BT.com
Wishlist
Samsung 500GB 840 EVO Series SATA 6Gb/s 2.5" SSD Laptop Upgrade Kit
Delivery
Standard 1-3 working days
Samsung 500GB 840 EVO Series SSD with Laptop Upgrade Kit
Kit includes SSD, Mounting Spacer Bar, USB3 To SATA Connector, CD with Data Migration, Magician Software & Manual)
The Samsung SSD840 EVO is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MEX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
  • Capacity: 500GB
  • Sequential Read: 540MB/s
  • Sequential Write: 520MB/s
  • Random Read (QD32, 4KB): 98,000 IOPS
  • Random Write (QD32, 4KB): 90,000 IOPS
  • Random Read (QD1, 4KB): 10,000 IOPS
  • Random Write (QD1, 4KB): 33,000 IOPS
  • Warranty: 3 Year
Samsung 840 EVO Laptop Kit MZ-7TE500LW - solid state drive - 500 GB - SATA 6Gb/s
Solid state drive - internal
500 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
TRIM support, Automatic Garbage Collection, Samsung 3-core MEX Controller, Low Power DDR2 SDRAM Cache, S.M.A.R.T., 256-bit AES
69.85 mm x 100 mm x 6.8 mm
53 g
3 years warranty
500 GB
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100 mm
6.8 mm
53 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
98000 IOPS
4KB Random Write
90000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
0.1 Watt (active) , 0.045 Watt (idle)
Software Included
Drivers & Utilities, Samsung Magician Software
2.5mm mounting spacer, SATA to USB 3.0 adapter
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 0.5ms (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Disk is great, less so the upgrade kit
Reviewed by Paul on 26/12/2014
The disk itself is a solid product. I got it as a replacement for a failing laptop hard drive. However the experience with the upgrade kit was less so.
The failing hard drive had a bad sector. Unfortunately the bundled drive clone program aborted the copy operation every time it got to that sector, so that was no use. I wound up using GNU ddrescue, which does a really great job but needs some technical knowledge. I don't know what I'd recommend for someone wanting a point and click solution.
The kit includes a SATA to USB3 adapter, which worked well but got very hot in one spot. I wouldn't want to leave it unattended or rely on it for regular use.
Scroll to top
