BT.com
Wishlist
Samsung 320GB Spinpoint M8 SATA 3GB/s 8MB 5400RPM 2.5" Hard Drive
Delivery
Standard Due date unavailable
Samsung
  • Max. 500GB formatted capacity per disk
  • ATA Security Mode Feature Set
  • SATA Native Command Queuing Feature
  • ATA S.M.A.R.T. Feature Set
  • TuMR/PMR head with FOD technology
  • SilentSeek™
  • Serial ATA 3.0Gbps Interface Support
  • NoiseGuard™
  • Load/Unload Head Technology
  • Capacity 320GB
  • Interface: 3GB/s
  • Buffer DRAM Size 8MB
  • Rotation Speed 5400RPM
  • Average Seek Time 12ms
  • Data Transfer Rate Buffer to/from Host (Max.) 300MB/s
Dimensions
  • Height 9.5mm
  • Width 69.85mm
  • Length 100.3mm
  • Weight 107g
Samsung SpinPoint M8 HN-M320MBB - hard drive - 320 GB - SATA 6Gb/s
Hard drive - internal
320 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology , S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
107 g
320 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
8 MB
70 mm
100 mm
9.5 mm
107 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
145 MBps
Seek Time
12 ms (average)
Average Latency
5.6 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x internal - 2.5" x 1/8H
5 °C
55 °C
5 - 90% (non-condensing)
Shock Tolerance
325 g @ 2ms half-sine pulse (operating) / 750 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
1.5 g @ RMS (random) (operating)
Resources
The following resources are available for the Samsung 320GB Spinpoint M8 SATA 3GB/s 8MB 5400RPM 2.5" Hard Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* As described
Reviewed by T. H. on 23/12/2013
For the price this is a good reliable disk. I bought this after reading the reviews and am happy with it.
Scroll to top
