BT.com
Wishlist
Samsung 250GB 850 EVO Series SATA 6Gb/s 2.5" SSD Retail Kit
Samsung 250GB 850 EVO Series SATA...
£104.98
£104.98
Add to wishlist
Delivery
Standard 1-3 working days
Achieve the ultimate read/write performance to maximize your everyday computing experience with Samsung's TurboWrite technology. You not only obtain more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds. The 850EVO delivers the top of its class performance in sequential read and write speeds. Plus, you also gain optimized random performance in all QD for client PC usage scenario.
Samsung's Magician software which provides rapid mode for 2x faster processing data speeds on a system level by utilizing unused PC memory (DRAM) as cache storage. The Magician increased the maximum memory usage in rapid mode. You also get a 2x performance boost in all random queue depth.
The 850 EVO delivers significantly longer battery life on your notebook with a controller optimized for 3D V-NAND now enabling device sleep at a highly efficiency. The 850 EVO is now 25% more power efficient during write operations thanks to 3D V-NAND only consuming half the energy than that of planar 2D NAND.
Samsung 850 EVO MZ-75E250 - solid state drive - 250 GB - SATA 6Gb/s
Solid state drive - internal
250 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
512 MB
Hardware Full Disk Encryption (FDE), TRIM support, DRAM cache, DevSleep mode, 3D V-NAND Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Worldwide Name (WWN), RAPID mode support, TurboWrite Technology, Samsung MGX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
41 g
5 years warranty
250 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100 mm
6.8 mm
41 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 520 MBps (write)
4KB Random Read
97000 IOPS
Maximum 4KB Random Write
880000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.4 Watt (average) , 2 mW (sleep) , 2.4 Watt (maximum) , 50 mW (idle)
Software Included
Samsung Magician Software
SATA to USB 3.0 adapter, mounting spacer
Limited warranty - 5 years
70 °C
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine pulse
Other bundles
Samsung 250GB 850 EVO Series SATA 6Gb/s 2.5" SSD Retail...
£104.98
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.42
£108.40
Scroll to top
