BT.com
Wishlist
Samsung 24x SH-224DB DVD-RW SATA OEM
Delivery
Standard Due date unavailable
The SH-S224 drive offers a powerful over-speed performance feature that enables consumers to burn data at high speeds - even on low speed media. With over-speed recording, users can write at 24X speeds on 16X media and 12X speeds on 8X media. As lower speed media is more cost-effective, users can save money while burning discs at faster speeds.
The SH-S224 drive provides blazing recording speeds across a gamut of different data media types including 24X DVD±R recording, 12X DVD-RAM recording, 16X DVD+R Dual Layer recording, 12X DVD-R Dual Layer recording, 8X DVD+RW recording and 6X DVD-RW recording. It enables consumers to burn 4.7GB on a DVD±R disc in approximately 4 minutes and 26 seconds, a 6 percent increase in speed compared to a 20X DVD writer. It also takes less than 12 minutes to burn 4.7GB in DVD-RAM format, which is a 30 percent increase in speed over a 20X DVD drive.
Samsung's SH-S224 drive supports SATA interface, the dominant interface for PCs.
As with Samsung's complete WriteMaster optical disc drive lineup, the SH-S224 features specific technology that ensures best-of-breed performance including SAT1 (Speed Adjustment Technology), TAC2 (Tilt Actuator Compensation) and Double OPC3 (Optimum Power Control). Buffer Under Run Free Technology4 supports stable writing under high speed, and Magic Speed5 and ABS (Automatic Ball Balancing System) 6 technologies reduce vibration and noise. The SH-S224 is also eco-friendly designed and is RoHS compliant.
Write Speed
  • DVD-R: 24x
  • DVD-R: 24x
  • DVD-R DL: 12x
  • DVD+R DL: 16x
  • DVD+RW: 8x
  • DVD-RW: 6x
  • DVD-RAM: 12x
  • CD-R:48x
  • CD-RW: 4x
Read Speed
  • DVD-R: 16x
  • DVD+R: 16x
  • DVD-R DL: 12x
  • DVD+R DL: 12x
  • DVD-RW: 12x
  • DVD+RW: 12x
  • DVD-RAM: 12x
  • CD-R: 40x
  • CD-RW: 40x
Samsung Super-WriteMaster SH-224DB - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
DVD±RW (±R DL) / DVD-RAM drive - internal
Serial ATA
14.82 cm x 17 cm x 4.2 cm
750 g
Optical Storage
DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 24x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Buffer Underrun Protection
Media Load Type
Tray
Serial ATA
14.82 cm
17 cm
4.2 cm
750 g
Optical Storage
Read Speed
Write Speed
Supported Media Formats
CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, CD-ROM, CD+G (Karaoke CD), DVD-Video
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, DVD-ROM DL
Media Load Type
Tray
Access Time
150 ms (DVD), 170 ms (CD)
Buffer Size
1.5 MB
Speed Adjustment Technology (SAT), Tilt Actuator Compensation (TAC), Double Optimum Power Control, firmware upgradable, Speed Plus
CD-Bridge
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
RoHS
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Surprisingly Quiet
Reviewed by Bearslumber on 19/09/2014
I bought a returned version of this DVD Writer for a fraction of the cost. Although not in its box, it was clear that the dvd writer was new.
Installation was easy and it was recognised first time by the Bios and Windows 7. Writing to dvd's was just as easy.
What surprised me the most was the silence in which it does it. I have bought many such in my lifetime and all were many decibels louder, even though very good.
I note the Samsung logo in the front was missing altogether.
5* Very good...
Reviewed by Steve on 07/07/2014
Well, I have only loaded on Windows with it, but it was fast and without errors. It comes with no software or SATA cables, so bear that in mind, but for the money, it's great. I do miss the Pioneer drives though!
5* Samsung Quality Drive!
Reviewed by Donald on 09/12/2013
After reviewing a couple of drives that I would like to use, I ended up selecting this one and do not regret it. The drive is excellent!
4* Good DVD drive but tray looking very weak
Reviewed by Bergamot Eng. on 23/09/2013
I hesitated between buying this drive and a LiteOn one that was only 50p more (£13 vs £12.5 in August 2013).
I bought the LiteOn one for 1 computer and the Samsung one for another.
As the LiteOn one looks a bit stronger I think it is worst the extra 50p.
Otherwise the Samsung mark on the front of the tray is not as big as the picture suggest it which was a good surprise.
This Samsung drive is still a good buy, especially as it is very cheap.
2* Samsung 24x SH-224DB DVD-RW SATA OEM
Reviewed by Steve on 24/05/2015
Bought this less than a year ago. Initially I was impressed, easy install and worked great. Used it to install the operating system, but 3 months later when I needed it the carriage was sticking, struggled to open and close, when it did close the disk vibrated like hell and it was unable to be read. Checked for over-tight screws. Probably lacked sufficient lubrication. Returning it for warranty would be more expensive than the cost, so just bought another one from a local supplier. I might fix it myself some time. Disappointing result.
Scroll to top
