BT.com
Wishlist
Samsung 1TB T3 USB 3.1 External SSD
Delivery
Standard Due date unavailable
Portability is the key element shared among all digital devices today where everything, including you, is constantly moving. When you are always on-the-go, your data should be, too. Born and bred with potent portability in its core, the Samsung Portable SSD T3 is built strong and light and is equipped with a built-in security feature. Most of all, it offers the blazing-fast data transfer speed of up to 450 MB/s. With compatibility across multiple operating systems and devices, the T3 will take your data to another level of accessibility.
Samsung Portable SSD T3 MU-PT1T0B - solid state drive - 1 TB - USB 3.1 Gen 1
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Shock resistant, USB Attached SCSI Protocol (UASP) compliant, 256-bit AES
Power Source
USB bus
7.4 cm x 1.05 cm x 5.8 cm
51 g
3 years warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen 1
7.4 cm
1.05 cm
5.8 cm
51 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
450 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Apple MacOS X 10.7 or later, Android 4.4 (KitKat) or later
UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC
Limited warranty - 3 years
Scroll to top
