BT.com
Wishlist
Samsung 1TB Spinpoint M8 2.5" SATA 3Gb/s 5400RPM 8MB 9.5mm
Delivery
Standard Due date unavailable
Wings on your mobile! Samsung’s Spinpoint M8 series employs advanced format technology (AFT) that raises the data storage density per unit area, enabling efficient and convenient data storage. It operates on a high-performance 3 gigabits per second SATA interface, provides an eight megabyte buffer memory and incorporates EcoSeek and NoiseGuard features for minimal noise levels. A redesign of the overall structure ensures enhanced shock resistance to protect the disc from physical fracture and data loss. Fast and reliable with a 5400rpm spin speed and 8MB buffer, Samsung’s Spinpoint M8 series is the perfect choice for use in mobile computing applications such as notebooks
Samsung SpinPoint M8 HN-M101MBB - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Load/unload technology, NoiseGuard, SilentSeek technology, Native Command Queuing (NCQ), Tunnel Magneto-resistive Recording (TMR) Head Technology, Perpendicular Magnetic Recording (PMR), Flying On Demand (FOD) Technology, EcoTriangle, EcoSeek, S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
107 g
Microsoft Certification
Compatible with Windows 7
1 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
8 MB
70 mm
100 mm
9.5 mm
107 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
145 MBps
Seek Time
12 ms (average)
Average Latency
5.6 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
5 °C
55 °C
5 - 90% (non-condensing)
Shock Tolerance
325 g @ 2ms half-sine pulse (operating) / 750 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
1.5 g @ RMS (random) (operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Nice little drive
Reviewed by Archie on 08/01/2012
I was looking for a large capacity storage device for an HTPC based on the Shuttle XS35GT V2 and this certainly fits the bill. It slotted straight into the chassis with no fuss and was detected immediately by the BIOS. It is very quiet, so quiet in fact that you have to have your ear right up to the case to hear it working. An all round excellent product at a reasonable price, which is what I have come to expect from Samsung.
4* Excellent reliable drive ...
Reviewed by Mark H on 03/09/2013
I bought one from BT about 10 months ago as a second drive for my Samsung laptop. Installation was simple without having to fiddle in the BIOS and all I had to do was partition and format it the way I wanted it ... 10 months on it has had an absolute beating from me shifting hundreds of gigabytes of data on and off the drive every day, repeatedly for various projects, running the laptop and drive sometimes continuously for several days while I slept and did other work. And it still works with not one failure.
3* Failed drive
Reviewed by Kerry on 14/08/2013
Disappointed with this drive only lasting 18months before fatal errors making the drive unusable. Will avoid Samsung brand.
Up till it failing it has been great.
2* Failing Drive
Reviewed by Ed on 14/09/2013
Samsung HN-M101MBB HDD: Bad sectors resulting in significant data loss after approx. 14 months' intermittent use. BT: Excellent service.
Scroll to top
