BT.com
Wishlist
Samsung 1TB M2 Portable USB 2.0 Piano Black
Delivery
Standard Due date unavailable
With a refined, clean Scandinavian design, the M2 Portable series holds your attention along with your precious data. It also holds up to day-to-day use, thanks to the scratch-resistant, fingerprint-resistant wave-patterned matte finish that preserves its timeless beauty. The M2 Portable series design is functional, as well: with concave sides for a better grip when you hold it; so, you'll feel secure when taking it on the go.
Protect the Earth and your precious data at the same time. The M2 Portable series external hard drive features Samsung's Eco Triangle technology. Its eco-friendly components are halogen-free without compounds such as BFPs and CFPs. Optimized energy-efficiency helps lower power consumption and utility bills, while its "Eco Seek" and top-quality "noise guard" acoustic technology provide whisper-quiet operation to let you work without distraction. As conscientious as it is efficient, it's the hard drive that thinks "planet first".
Presenting the slim, compact data storage solution that redefines portability. The M2 Portable series external hard drive is a mere 17.60 mm thick-but don't be fooled by its ultra-small size. Designed to carry massive amounts of digital content on the go, it makes the perfect traveling companion for your notebook or DSLR camera. You don't even need to bring along a separate power supply-the M2 Portable series is powered directly by the USB port on your computer.
Samsung M2 Portable HX-M101UAB - hard drive - 1 TB - USB 2.0
Hard drive - external (portable)
1 TB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
USB bus
Enclosure Colour
Brown black
8.2 cm x 11.1 cm x 1.8 cm
155 g
3 years warranty
1 TB
2.5"
USB 2.0
8.2 cm
11.1 cm
1.8 cm
155 g
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.8 or later
1 x USB cable - 45 cm
Enclosure Colour
Brown black
3 years warranty
Limited warranty - 3 years
5 °C
Scroll to top
