BT.com
Wishlist
Samsung 16GB DDR4 PC4-19200 2400MHz ECC Reg CL17 1.2V DIMM
Delivery
Standard Due date unavailable
Samsung DDR4 DIMMs are designed with an additional hardware register between the DRAM module and the system's memory controller. RDIMMs present several advantages for the system, such as a lower electrical load on the memory controller and sustained stability even with an increase in the number of installed memory modules. Thus, RDIMMs are often the default choice for deployment in server-class computing systems.
In addition to DIMM's features, Samsung DDR4 memory provides an optimized solution for highly virtualized environments, high-performance computing and networking. Semiconductor modules of Samsung DDR4 are designed with system circuit architecture to deliver higher performance with low power requirements than previously available memory products. Doubled bandwidth, along with reduced voltage and dramatically lower power consumption, improves performance and optimizes the total cost of ownership. Samsung DDR4's enhanced reliability, availability and serviceability (RAS) features provide enhanced reliability and improved signal integrity (S/I).
Samsung - DDR4 - 16 GB - DIMM 288-pin - registered with parity
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Registered with parity
Voltage
1.2 V
16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
2048 x 72
Chips Organization
2048 x 4
Voltage
1.2 V
Scroll to top
