BT.com
Wishlist
Samsung 128GB 830 Series SATA 6Gb/s 2.5" SSD Basic Kit
Delivery
Standard Due date unavailable
The Samsung 830 Series Basic Kits Include SSD, Manual & Magician Software CD
The Samsung SSD 830 Series boasts superior random read speeds and faster sequential read and write speeds. It's the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
  • Samsung 3-core MCX controller
  • Samsung 2x nm Toggle DDR NAND Flash memory
  • Samsung 256MB DDR2 SDRAM cache memory
  • Magician software for SSD management
  • Black-tone, brushed metal design
  • Only 7mm thick to accommodate the latest slim-profile laptop PCs
Outstanding Performance in Multi-tasking
The Samsung SSD 830 Series boasts superior random read speeds (up to 80,000 IOPS) and faster sequential read and write speeds (up to 520 MB/s & 400 MB/s respectively). It's the ideal solution for your everyday computing needs, such as web browsing, document creation, viewing or editing multimedia files, playing PC games, etc.
Superior Reliability
As the world's #1 DRAM, NAND Flash, and SSD supplier, Samsung has unique, industry-leading engineering resources, technologies, and manufacturing processes as well as more stringent quality and testing standards. All Samsung SSDs are designed and built completely in-house, rather than sourcing generic parts from the market. The Samsung SSD 830 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms.
Industry-leading Design
The Samsung SSD 830 Series features stunning design and precision engineering - inside and out. It measures only 7mm thick, so it can even accommodate the latest ultra-slim laptop PCs.
Magician Software
Samsung's SSD Magician software eliminates the confusion and uncertainties of SSD management, making it simple for users to maximize the performance and lifetime of their Samsung SSD. The software helps to maintain the SSD at its peak condition, giving you the same great performance and reliability throughout the life of your PC. In addition to its performance maintenance features, SSD Magician also provides system information and facilitates performance benchmarking, performance optimization, OS optimization, firmware updates, secure erasing, and over provisioning.
Technical Specifications
  • Dimensions (L* W* H): 100 x 69.85 x 7 (mm)
  • Interface: SATA 6Gb/s (compatible with SATA 3Gb/s and SATA 1.5Gb/s)
  • Form Factor: 2.5 inch
  • NAND Flash Memory: 2x nm Samsung Toggle DDR MLC NAND Flash Memory
  • Performance*: Sequential Read: Max. 520 MB/s (64GB/128GB/256GB/512GB)
  • Sequential Write: Max. 400 MB/s (256GB/512GB)
  • 4KB Random Read: Max. 80,000 IOPS (128GB/256GB/512GB)
  • 4KB Random Write: Max. 36,000 IOPS (256GB/512GB)
  • TRIM Support: Yes (Requires OS Support)
  • Garbage Collection: Yes
  • S.M.A.R.T: Yes
  • Weight: Max. 62.5g (256GB/512GB)
  • Reliability: 1.5 million hours MTBF (Mean Time Between Failures)
  • Power Consumption: Active : 0.127W * (Typical) Idle : 0.078W** (Typical)
  • Shock: 1500G & 0.5ms (Half sine)
  • Warranty: 3 years
  • Performance measurements based on Iometer with queue depth equal to 32. / * Active power is measured during execution of MobileMark 2007 in Windows 7 / ** DIPM enabled value
Samsung 830 Series MZ-7PC128B - solid state drive - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
2.5" Ultra Slim Line
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
TRIM support, Garbage Collection technology, S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
61 g
3 years warranty
128 GB
SATA 6Gb/s
Buffer Size
256 MB
69.85 mm
100 mm
7 mm
61 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 320 MBps (write)
4KB Random Read
80000 IOPS
4KB Random Write
30000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
Software Included
Norton Ghost 15, Samsung Magician Software 3.0
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits)
Limited warranty - 3 years
60 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Samsung 830 128GB
Reviewed by Dan on 21/05/2012
Plug and Play, easy to install, had it a few weeks now with no issues. Speeds are consistently 440-330mp/s read and write on my Dell laptop.
5* 830 Series - Raid 0
Reviewed by Anonymous on 05/06/2012
I've got two of these in Raid 0. I installed Win 7 ultimate 64 in eight mins and boot to windows in 8 secs. The highest read I have had is 959mbs and 628 write. Only drawback is the Samsung software does not recognize raid arrays
5* Oh yes... Thank you Samsung.
Reviewed by Anonymous on 14/06/2012
I got this to replace a "Kingston 60GB SSD Now" in an older SATA2 machine. The write speeds have greatly improved to approx 170MB/s and read speeds are 236MB/s. Booting is faster, loading Photoshop CS5.5 or Word is 1-3 seconds. Productivity is greatly improved due to being so quickly able to switch programs and get files loaded. Amazing results, excellent service from BT. I could not be happier at this time.
5* SSD
Reviewed by Anonymous on 16/06/2012
BT usual very fast delivery. This is my first try with an SSD and it is very impressive. My system speed is at least 4 time faster than it was. I ghosted my HDD with the included software. A bit of a faff but not too bad. It is recommended that you do a clean install, but I have my WIN7 system just how I want it. So, overall I would happily recommend this SSD. Hopefully the 3 year guarantee is a good indicator of its lifespan.
Scroll to top
