BT.com
Wishlist
Samsung 120GB 840 Series SATA 6Gb/s 2.5" Solid State Drive Kit
Delivery
Standard Due date unavailable
120GB 2.5-inch SSD 840 Series Solid State Drive with Full Kit
The Single Best Upgrade for Your PC
With its simple 3-Step migration solution and industry-leading IOPS performance, the Samsung SSD 840 Series is the single best upgrade you can make for your PC. Samsung's new SmartMigration software takes the guesswork and headache out of moving your operating system and precious data to your new SSD. Once you're up and running, the 840 Series' amazing IOPS speeds empower you to multitask like never before.
Upgrading to an SSD is the easiest and most economical way to breathe new life into an aging PC. Today, most PC performance woes are the result of slow read and write speeds on behalf of the main storage device, not a lack of CPU performance. Upgrading to a Samsung SSD 840 Series can breathe new life into your old PC by enhancing boot-up speed, application loading, and multi-tasking performance.
Superior Reliability
As the world's #1 DRAM, NAND Flash, and SSD supplier; Samsung SSDs are designed and built completely in-house. The Samsung SSD 840 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms backed by a 3-year limited warranty.
Magician Software
Samsung's Magician software has been completely redesigned with an extreme focus on usability. Magician makes it simple for users to maximize the performance and lifetime of their Samsung SSD. In addition, SSD Magician also provides system information and facilitates performance benchmarking, performance optimization, OS optimization, firmware updates, secure erasing, and over provisioning. Newly introduced Drive Health Status, Total Bytes Written (TBW), and Disk Scan & Error Reporting functionality make Magician one of the most useful storage utilities available.
A Complete, User-Friendly Solution
The Samsung SSD 840 Series is available with a simple, all-in-one installation kit. The kit comes with SATA data and power cables, screws, a 2.5-inch to 3.5-inch adapter bracket, a SATA to USB adapter cable to facilitate easy data migration, and a mounting spacer so that laptops with traditional 9.5mm drive bays can accommodate the Samsung SSD 840 Series' slim 7mm profile.
  • Solid State Drive with Notebook + Desktop Upgrade Kit
  • 2.5" 7mm (Ultraslim) Form Factor
  • 840 Series
  • Capacity: 500GB
  • Sequential Read Speed: Up to 530MB/s
  • Sequential Write Speed: Up to 130MB/s
Samsung 840 Series MZ-7TD120 - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
2.5" Ultra Slim Line (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Garbage Collection technology , S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
68 g
3 years warranty
120 GB
SATA 6Gb/s
69.85 mm
100 mm
7 mm
68 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
530 MBps (read) / 130 MBps (write)
4KB Random Read
85000 IOPS
4KB Random Write
32000 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" Ultra Slim Line or 3.5" (with included bay adapter)
Software Included
Drivers & Utilities, Samsung Smart Migration Software
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits)
3.5-inch bay adapter, SATA to USB adapter, 2.5mm mounting spacer
Limited warranty - 3 years
60 °C
Scroll to top
