BT.com
Wishlist
Ruckus ZoneFlex R700 dual-band 802.11abgn/ac Wireless Access Point
Delivery
Standard Due date unavailable
The ZoneFlex R700 ensures the most reliable connectivity within challenging and ever-changing RF environments. With BeamFlex+, the ZoneFlex R700 is capable of delivering 6 dB of signal-to-interference-plus-noise (SINR) improvement and up to 15 dB of interference mitigation over other APs. The ZoneFlex R700 simultaneously supports spatial multiplexing and BeamFlex+ to deliver the best price/performance of any three-stream 802.11ac AP.
ZoneFlex R700 is purpose-built for high-capacity, high performance and interference-laden environments such as airports, public venues, hotels, universities and conference centers. The perfect choice for data-intensive streaming multimedia applications, the ZoneFlex R700 delivers picture perfect HD-quality IP video while supporting VoIP and data applications that have stringent quality of service requirements.
Ruckus ZoneFlex R700 - radio access point
Radio access point
External
Worldwide
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Concurrent stations: 500 , Simultaneous VoIP clients: 60
Power Over Ethernet (PoE) Supported
PoE
20.3 cm x 20.3 cm x 5 cm
1 kg
Radio access point
20.3 cm
20.3 cm
5 cm
1 kg
Worldwide
External
Wireless
Data Transfer Rate
1300 Mbps
Network / Transport Protocol
L2TP, PPPoE
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, DHCP support, NAT support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IPv6 support, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), IPv4 support, Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Space Time Blocking Code (STBC), ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
AES, WPA-PSK
Authentication Method
RADIUS, LDAP, Basic Service Set Identifier (BSSID), Active Directory
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
Internal
2 x 1000Base-T (PoE) - RJ-45
UL 2043, RoHS, WEEE, EN 60601-1-2, EN 50121-4, IEC 61373, EN 50121-1
PoE
Limited warranty - lifetime
50 °C
0 - 95% (non-condensing)
Scroll to top
