BT.com
Wishlist
Ruckus ZoneFlex R300 dual band 802.11n Indoor Wireless Access Point
Delivery
Standard Due date unavailable
The Ruckus ZoneFlex R300 delivers high-performance and reliable 802.11n wireless networking at the industry's most affordable price point. Unlike any other 802.11n wireless solution in its class, the ZoneFlex R300 combines patented adaptive antenna technology and automatic interference mitigation to deliver consistent, predictable performance at extended ranges with up to an additional 4 dB of BeamFlex gain on top of the physical antenna gain and up to 10 dB of interference mitigation. Additional performance enhancements to signal gain can be attributed to the chip-based transmit beam forming capability adding 3 dB when associated to a compatible client.
Each ZoneFlex R300 integrates Ruckus-patented BeamFlex, a software-controlled, high gain antenna array that continually forms and directs each 802.11n packet over the best performing signal path. The ZoneFlex R300 automatically selects channels for highest throughput potential using Ruckus ChannelFly dynamic channel management, adapting to environmental changes. Once deployed, enterprises never have to worry about constant site surveys as the environment changes.
Ruckus ZoneFlex R300 - radio access point
Radio access point
13 cm
13 cm
2.8 cm
379 g
Worldwide
External
Wireless
Data Transfer Rate
300 Mbps
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Network / Transport Protocol
L2TP, PPPoE
Remote Management Protocol
SNMP 1, SNMP 2, SNMP, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Selectable Channels Qty
11
Concurrent stations: 256 , Simultaneous VoIP clients: 30
Status Indicators
Power, status
Auto-sensing per device, DHCP support, NAT support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), manageable, wall mountable, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK
Authentication Method
RADIUS, LDAP, Active Directory
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45
RoHS, WEEE, EN 60601-1-2
Power Over Ethernet (PoE) Supported
PoE
Limited warranty - lifetime
15 - 95% (non-condensing)
Scroll to top
