BT.com
Wishlist
Ricoh SPC440dn A4 Colour Laser Printer
Ricoh SPC440dn A4 Colour Laser...
£730.44
£730.44
Add to wishlist
Delivery
Standard 1-3 working days
The advanced SP C440DN has a sophisticated feature set providing best-in-class total cost of ownership for an A4 mid-range color printer. An output speed of 40ppm combined with an impressive array of security functions, flexible media options and eco-friendly operation make the SP C440DN the ideal solution for your color print needs. And an ECOnomy color output mode significantly reduces the cost compared to full color printing.
A 40ppm output speed allows you to benefit from improved efficiency for print jobs. Using the optional XPS Direct Print Option you can even print straight from a PC or USB device without a driver for complete flexibility. A maximum 2300 sheet paper capacity means the SP C440DN can easily meet all your output needs, producing labels and flyers in color.
Ricoh SP C440DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
57 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm) , Up to 40 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 40 ppm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, USB 2.0 host
RM7035 533 MHz
RAM Installed (Max)
1 GB (1 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Media Type
Envelopes, plain paper, glossy paper, coated paper, recycled paper, lettering tape, thick paper, thin paper, label paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
550-sheet input tray, 100-sheet bypass tray
Monthly Duty Cycle (max)
150000 pages
Print server
AC 230V
HP-UX 11.x, IBM AIX 5L, HP-UX 11i v2, SCO OpenServer 5.0.7, Microsoft Windows Server 2003, SunSoft Solaris 2.9, IBM AIX 5.3, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1, Apple MacOS X 10.7 - 10.10
44.4 cm x 65.8 cm x 49 cm
Printer Type
Printer
Print Speed
Wired
1200 x 1200 dpi
1200 x 1200 dpi
Direct Printing Specifications
PictBridge
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10 sec
First Print Out Time Colour
15 sec
Language Simulation
Fonts Included
58 x PCL , 136 x PostScript 3
Media Handling
RM7035 533 MHz
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
216 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
Media Weight
52 g/m² - 256 g/m²
650 sheets
Media Feeders
1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 256 g/m²
Max Media Capacity
2300 sheets
Duty Cycle
150000 pages
Print server
Security Protocols & Features
LDAP, 802.1x
1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner refill (black) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (yellow) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (magenta) - up to 3000 pages ISO/IEC 19798 , 1 x toner refill (cyan) - up to 3000 pages ISO/IEC 19798
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
771 Watt
Power Consumption Stand by
157 Watt
Power Consumption Sleep
0.66 Watt
Environmental Standards
ENERGY STAR
44.4 cm
65.8 cm
49 cm
57 kg
Scroll to top
