BT.com
Wishlist
Ricoh SPC340DN A4 Colour Laser
£226.17
£226.17
Add to wishlist
Delivery
Standard Due date unavailable
A fast processing A4 colour printer, the SP C340DN model more than meets the demands of most small to medium sized offices. You'll appreciate the low start-up costs, as well as the ability to print much more quickly and efficiently - thanks to its high-speed processor. Workflow is maximised with innovations like WiFi Direct (optional) where you can print from smart devices without connecting to a network. And the range of paper capacity, handling options and fast network connection all add to its efficient productivity
  • High-speed processor - much quicker on large print jobs
  • Print eye catching colour banners of up to 1,260 mm in length
  • High paper capacity and 25ppm print speed
  • 1200 x 1200 dpi colour printing
Ricoh SP C340DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Printer
Print Speed
Up to 25 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 25 ppm - colour duplex - A4 (210 x 297 mm)
Built-in Devices
Status LCD
Wired
USB 2.0, Gigabit LAN, USB host
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Direct Printing Specifications
PictBridge
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
13.5 sec
First Print Out Time Colour
13.5 sec
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF
Fonts Included
45 x PCL , 13 x Intellifonts , 136 x PostScript 3
Media Handling
500-sheet input tray, 100-sheet bypass tray
Intel Atom 1.46 GHz
RAM
RAM Installed (Max)
2 GB / 2 GB (max)
Media Handling
Media Type
Envelopes, plain paper, glossy paper, coated paper, recycled paper, thick paper, thin paper, middle thick paper, label paper, preprinted paper
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
Total Media Capacity
600 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
1100 sheets
Output Trays Capacity
150 sheets
Duty Cycle
Monthly Duty Cycle (max)
75000 pages
Print server
Security Protocols & Features
LDAP, 802.1x
1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 2500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1500 pages ISO/IEC 19798
ISO 9001, ISO 14001, ISO 27001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1.3 kW
Power Consumption Sleep
0.5 Watt
HP-UX 11.x, Apple MacOS 8.6 or later, HP-UX 11i v2, SCO OpenServer 5.0.7, SunSoft Solaris 2.9, Red Hat Enterprise Linux 4, SCO OpenServer 6, SunSoft Solaris 2.10, IBM AIX 5L 5.3, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, IBM AIX 5L 6.1, IBM AIX 5L 7.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Environmental Standards
ENERGY STAR
40 cm
48 cm
38.7 cm
29 kg
Scroll to top
