BT.com
Wishlist
Ricoh SP150-A4 Desktop Printer
£67.09
£67.09
Add to wishlist
Delivery
Standard Due date unavailable
If you need to get the job done, the SP 150 is the printer for you. Designed to make you more productive, its simple installation process and 22ppm output means you can enjoy its reliability, intuitive operation and sleek design, almost straight out-of-the-box.
Its simplicity means you can get on with what you need to do, safe in the knowledge that all your printing needs are taken care of. No matter if it's home or small business print requirements.
Ricoh SP 150 - printer - monochrome - laser
Printer Type
Personal printer - laser - monochrome
6.5 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 22 ppm - max speed
Max Resolution (B&W)
1200 x 600 dpi
USB 2.0
Language Simulation
Windows GDI driver
Media Type
Plain paper
Total Media Capacity
50 sheets
AC 230V
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Windows 10, Apple MacOS X 10.8 - 10.11
2 years warranty
35.1 cm x 26.6 cm x 10.6 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0
1200 x 600 dpi
First Print Out Time B/W
11 sec
Language Simulation
Windows GDI driver
Media Handling
Media Type
Plain paper
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 105 g/m²
50 sheets
Media Feeders
1 x automatic - 50 sheets
1 x USB 2.0
Consumables Included
1 x toner cartridge - up to 700 pages ISO/IEC 19752
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
350 Watt
Power Consumption Sleep
1.2 Watt
Environmental Standards
ENERGY STAR
35.1 cm
26.6 cm
10.6 cm
6.5 kg
Scroll to top
