BT.com
Wishlist
Ricoh SP 5210SF 50PPM A4 Mono Laser MFP
Delivery
Standard Due date unavailable
Where space is at a premium, the compact A4 black and white multi-functional, the Aficio SP SP 5210sf is ideal. It delivers 4-in-1 printing, copying, scanning and faxing to meet all your document needs. Packed with features usually expected only from larger MFPs, it is smaller but work just as hard. Your busy office or workgroup gets fast, affordable and versatile devices that can expand from desktop models to mighty four-tray, floor-standing powerhouses.
Ricoh SP 5210sf - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 50 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 50 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, thin paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
600 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB, LAN, Wi-Fi
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
46 cm x 51 cm x 68.6 cm
47 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Laser - monochrome
PC Connection
USB, LAN, Wi-Fi
Standard Memory
1 GB
Max Supported Memory
1 GB
Copying
Max Copying Speed
Up to 50 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Preset Enlargements
141%, 200%
Preset Reductions
50%, 71%, 93%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Up to 50 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3
Automatic Duplexing
Scanning
Scan Element
CCD
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Total Memory Capacity
Up to 320 pages
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
Legal
Min Media Weight
52 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 216 x 900 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
600 sheets
Input tray - 550 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , Bypass tray - 100 sheets - 216 x 900 mm weight: 52 g/m² - 220 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 52 ppm (Letter A) - B/W , Printing: up to 50 ppm (A4) - B/W , Copying: up to 50 ppm
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition
Software Included
Web Image Monitor, DeskTopBinder Lite, Remote Communication Gate S Pro, App2me, SmartDeviceMonitor
AC 230 V (50/60Hz)
1500 Watt
Power Consumption Standby
8 Watt
Warm Up Time
20 sec
First Copy Out Time B/W
7.5 sec
Consumables Included
1 x Cartridge (black)
Supported Windows 7 Features
Windows HD Imaging
ISO 9001, ISO 14001, ISO/IEC 19752
46 cm
51 cm
68.6 cm
47 kg
Scroll to top
