BT.com
Wishlist
Ricoh SP 4510SF A4 Mono Laser Printer
Ricoh SP 4510SF A4 Mono Laser...
£521.72
£521.72
Add to wishlist
Delivery
Standard Due date unavailable
Just because your budget is tight or your office is limited on space, it shouldn't limit what you can do. Use the Ricoh SP 4510SF to perform a wider range of everyday document management tasks - including printing, scanning, faxing and copying quickly - so you can move from one project to the next without missing a beat. Place the compact MFP nearly anywhere, even on your desk, to save space while you save time.
Customize the device to accommodate personal preferences. Take advantage of security controls to protect your information. Access administrative controls remotely to keep the SP 4510SF running efficiently - whether you add it to an integrated Ricoh Managed Document Services (MDS) portfolio or use it as your primary device.
Ricoh SP 4510SF - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
150000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi
Scanning
600 dpi
Display
4.3"
Original Size
100 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, recycled paper, thick paper, preprinted paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB 2.0 host
Office Machine Features
Save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to Cloud, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
41.9 cm x 42.7 cm x 48.4 cm
23 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
LED - monochrome
150000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
PC Connection
Standard Memory
1024 MB
Max Supported Memory
1536 MB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, Sort, auto start, rotation copy, margin shift, Auto Tray Switching (ATS), mixed size copy
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi
Max Battery Backup Time
12 hour(s)
Fax Machine Features
Fax forwarding, LAN fax, Dual Access, fax memory backup, Duplex Fax
Document & Media Handling
Min Original Size
100 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
52 g/m²
Max Media Weight
162 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), Foolscap (216 x 343 mm)
600 sheets
Max Media Capacity
1600 sheets
50 sheets
250 sheets
Input tray - 600 sheets size: 100 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Bypass tray - 50 sheets size: 60 x 127 mm - 216 x 900 mm weight: 52 g/m² - 162 g/m² , ADF - 50 sheets weight: 52 g/m² - 162 g/m²
Speed Details
Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ipm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, IPsec, 802.1x
Operating System Support
MS Windows XP, Red Hat Linux, IBM AIX, HP-UX, MS Windows Server 2003, MS Windows 7, Sunsoft Solaris, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later, Novell NetWare 6.5 or later, MS Windows Server 2012, Windows 8, SCO OpenServer, Windows 8.1, MS Windows Server 2012 R2
Software Included
Web Image Monitor, SmartDeviceMonitor, Web SmartDeviceMonitor
AC 230 V (50/60Hz)
1.1 kW
Power Consumption Standby
97.2 Watt
Power Consumption Sleep
0.72 Watt
Warm Up Time
19 sec
Consumables Included
1 x Cartridge (black) - up to 6000 pages
ISO/IEC 19752
ENERGY STAR Certified
41.9 cm
42.7 cm
48.4 cm
23 kg
Other bundles
£521.72
Save on TP Link Smart Plug
Save £2.00
£545.69
Scroll to top
