BT.com
Wishlist
Ricoh SP 400DN A4 Mono LED Desktop Printer
Ricoh SP 400DN A4 Mono LED Desktop...
£112.64
£112.64
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
More compact. More productive. More options.
In today’s marketplace, reliability and productivity is key, and you need a device you can count on. Of course, you want value for money too. So the SP 400DN is the perfect solution for small workgroups, cost-effective printing for a low-upfront cost. And featuring a 30ppm speed, it’s so compact, it could fi almost anywhere in your offie environment. With a 360,000 print lifetime and the ability to support a range of different paper thicknesses, you get the longevity you need, combined with the flxibility to do much more.
  • Can be positioned in limited spaces so it’s perfect for any office.
  • User-friendly with 4-line LED display panel so it’s easy to use.
  • Supports Smart Devices for mobile printing via our dedicated applications.
  • Handles standard offie and thick paper types from any tray.
  • ECO friendly, low power consumption through LED technology
Easy to print. From almost anywhere.
Enabling more, from less.
Our technology is designed to make every function you need easily accessible. And we’ve made sure this device is seamless to work with. The 4 line LED display panel gives you clear instructions and visual prompts, so you can focus on the task inhand, and just get the job done.
Print direct from your mobile.
You can print images, documents and more using the Ricoh Smart Device Print&Scan app from your Apple iPhone, iPad and Android Smart Devices. All you need to do is download the app and be on the same network. It’s really that simple.
Advance your business.
The technology behind the LED print-head not only improves quality, but enables it to be much smaller than traditional laser solutions. So you can put this capable device in a corner – or on a desk – of your company or home offie and it will take up minimal space, but keep on performing.
More options for print. And better for the environment.
The sheer range of paper stock it can handle means you have the ability to print on various kinds of papers and from any tray. It can print on thin paper to 162g/m2 thick paper, so there’s no wastage. And it even has low-power consumption with LED technology so your costs can be lower and it’s ECO friendly too.
Technology: LED
Warm-up time: e 14 seconds
First output speed: 6.5 seconds
Print speed: B/W: 30 pages per minute
CPU: Intel Celeron-M: 500 MHz GHz ARM Cortex A8
Memory: Standard: 256 MB GB
Maximum: 256 MB GB
Duty cycle: 50,000 prints per month
Duplex: Yes
Dimensions (W x D x H): 370 x 392 x 268 mm
Weight: 14.5 kg
Ricoh SP 400DN - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
14.5 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN
ARM Cortex-A8 500 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, plain paper, recycled paper, thick paper, thin paper, middle thick paper, label paper, preprinted paper
Total Media Capacity
350 sheets
Monthly Duty Cycle (max)
50000 pages
Print server
AC 230V
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10
37 cm x 39.2 cm x 26.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0, LAN
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Fonts Included
45 x PCL , 13 x Intellifonts , 136 x PostScript 3
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
52 g/m² - 162 g/m²
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
125 sheets
Duty Cycle
50000 pages
Print server
1 x USB 2.0 , 1 x LAN - RJ-45
ISO 9001, ISO 14001, ISO 27001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
990 Watt
37 cm
39.2 cm
26.8 cm
14.5 kg
Other bundles
£112.64
Save on TP Link Smart Plug
Save £2.00
£136.61
Scroll to top
