BT.com
Wishlist
Ricoh SP 3600SF 30 ppm A4 Mono LED Desktop MFP
Ricoh SP 3600SF 30 ppm A4 Mono LED...
£306.66
£306.66
Add to wishlist
Delivery
Standard 1-3 working days
This compact unit with a small footprint makes the SP 3600SF well suited to the needs of small offices that need to copy and scan as well as print. Standard connectivity is via USB or networked via Gigabit Ethernet. There is also the option of WiFi connection so the SP 3600SF can be conveniently located anywhere in the office where there is a power outlet. It takes up little space and uses minimal energy when not in use. But when needed the SP 3600SF is available for use in just 13 seconds, producing a first print in just 6.5 seconds and can handle large volumes of work in bust office environments.
Ricoh SP 3600SF - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
G3 - plain paper
Printing Technology
LED (monochrome)
Monthly Duty Cycle (max)
50000 pages
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
Media Type
Plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
125 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
40 cm x 39.2 cm x 40.6 cm
19 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
LED - monochrome
50000 pages
PC Connection
Standard Memory
512 MB
Copying
Max Copying Speed
Up to 30 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
6.5 sec
Scanning
Optical Resolution
600 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Fax memory backup
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4
Min Media Weight
52 g/m²
Max Media Weight
162 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
850 sheets
125 sheets
Input tray - 350 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Output tray - 125 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
Speed Details
Printing: up to 30 ppm (A4) - B/W , Copying: up to 30 ipm - B/W
1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Windows 8.1, Apple Mac OS X 10.6 or later, MS Windows Server 2012 R2
AC 230 V (50/60Hz)
1.006 kW
Power Consumption Sleep
1 Watt
Warm Up Time
19 sec
Consumables Included
1 x Cartridge (black) - up to 1500 pages
ENERGY STAR Certified
40 cm
39.2 cm
40.6 cm
19 kg
Scroll to top
