BT.com
Wishlist
Ricoh SP 3600DN 30ppm A4 Mono LED Desktop Printer
Ricoh SP 3600DN 30ppm A4 Mono LED...
£263.50
£263.50
Add to wishlist
Delivery
Standard 1-3 working days
The low total cost of ownership of the SP 3600DN A4 printer make it the ideal device for low volume, cost-effective desktop printing. With a warm-up time of only 13 seconds and print speed of 30 pages per minute with double-sided printing at 15 ppm the SP 3600DN is the perfect solution for personal printing or networked for use by small workgroups.
The SP 3600DN is ready to print in seconds generating high quality prints in no time. Double-sided printing as standard saves paper and reduces costs. Operating costs are also kept low with a typical electricity consumption value of 1.4 KWh, among the lowest in its sector.
Ricoh SP 3600DN - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
14.5 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN
500 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper, middle thick paper, preprinted paper
Total Media Capacity
350 sheets
Media Handling
350-sheet input tray
Monthly Duty Cycle (max)
50000 pages
Print server
AC 230V
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1
37 cm x 39.2 cm x 26.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0, LAN
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript 3 , 13 x Intellifonts
Media Handling
500 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
52 g/m² - 162 g/m²
350 sheets
Media Feeders
1 x automatic - 350 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , 1 x automatic - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
125 sheets
Duty Cycle
50000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
989 Watt
37 cm
39.2 cm
26.8 cm
14.5 kg
Scroll to top
