BT.com
Wishlist
Ricoh SP 311SFN Mono Laser Multifunction Printer
Ricoh SP 311SFN Mono Laser...
£109.89
£109.89
Add to wishlist
Delivery
Standard Due date unavailable
Small, smart and energy-efficient, the SP 311SFN is designed to impress. Compact enough to fit unobtrusively on a desk, the innovative B/W A4 laser MFP will astound you with their speed and efficiency. The device is easy to operate and simple to maintain. Their energy consumption is very low. And it incorporates a host of environmentally responsible features such as energy saver mode and automatic duplex to lower your carbon footprint. In short, if you're looking for fast, compact, energy-efficient B/W MFP, you'll find them in the SP 311SFN.
Ricoh SP 311SFN - multifunction printer (B/W)
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 28 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 1200 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Original Size
A4 (210 x 297 mm) (max)
Media Size
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
40.5 cm x 38.2 cm x 39 cm
17.5 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
4 lines
PC Connection
USB 2.0, LAN
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Up to 28 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6
Automatic Duplexing
Scanning
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Max Media Size
A4
Min Media Weight
52 g/m²
Max Media Weight
162 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
300 sheets
Max Media Capacity
300 sheets
50 sheets
50 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Bypass tray - 50 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , Output tray - 50 sheets - A4 (210 x 297 mm)
Speed Details
Printing: up to 28 ppm (A4) - B/W , Copying: up to 28 ppm (A4) - B/W , Scanning: up to 12 ppm (A4) - B/W , Scanning: up to 6 ppm (A4) - colour
1 x USB 2.0 , 1 x LAN - RJ-45
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2012
AC 230 V (50/60Hz)
890 Watt
Warm Up Time
30 sec
First Copy Out Time B/W
8 sec
ISO 9001, ISO 14001
ENERGY STAR Certified
40.5 cm
38.2 cm
39 cm
17.5 kg
Scroll to top
