BT.com
Wishlist
Ricoh SP 213w 22PPM A4 Mono Laser Printer
Ricoh SP 213w 22PPM A4 Mono Laser...
£75.81
£75.81
Add to wishlist
Delivery
Standard Due date unavailable
The SP 213w is an A4 black-and- white printer that will fit perfectly on your desktop. With its small footprint it won't take up valuable space. It's easy to use because all operations can be managed from the front of the device. Offering standard Wi-Fi, manual double-sided printing, an embedded paper tray and an all-in-one print cartridge, the SP 213w is ideal for small and home offices looking for a productive print solution.
Ricoh SP 213w - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
7.2 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 22 ppm - max speed
Max Resolution (B&W)
1200 x 600 dpi
USB 2.0, Wi-Fi(n)
RAM Installed (Max)
128 MB
Language Simulation
PCL 6
Media Type
Plain paper, recycled paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
20000 pages
Print server
AC 230V
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1
Microsoft Certification
Compatible with Windows 7
40.2 cm x 36 cm x 16.5 cm
Printer Type
Printer
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
1200 x 600 dpi
First Print Out Time B/W
10 sec
Language Simulation
PCL 6
Fonts Included
80 x PCL
Media Handling
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 105 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets weight: 60 g/m² - 105 g/m² , 1 x automatic - 1 sheet weight: 60 g/m² - 105 g/m²
Output Trays Capacity
50 sheets
Duty Cycle
20000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge - up to 700 pages ISO/IEC 19752
Power supply
AC 230V
Frequency Required
50/60 Hz
400 Watt
Power Consumption Stand by
65 Watt
Power Consumption Sleep
5 Watt
40.2 cm
36 cm
16.5 cm
7.2 kg
Other bundles
£75.81
Save on TP Link Smart Plug
Save £2.00
£99.78
Scroll to top
