BT.com
Wishlist
Ricoh SG 3100SNw Colour Geljet Multifunction Printer
Delivery
Standard Due date unavailable
Imagine the power of versatile color on demand. Rethink your approach to color multitasking with Ricoh's innovative GELJET multifunctionals. Equally at home in both retail and office environments, the Aficio SG 3100SNw provide fast color copying, printing, scanning and faxing for everyone. And they make it easy with simple front access, a small footprint and the cable-free connectivity of Wi-Fi.
Ricoh SG 3100SNw - multifunction printer (colour)
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Ink-jet (colour)
Inkjet Technology
Ricoh GelJet - 4-ink
Max Copying Speed
Up to 29 ppm (mono) / up to 29 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 3600 x 1200 dpi (mono) / up to 3600 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
A4 (210 x 297 mm) (max)
Media Size
Media Type
Plain paper
Standard Media Capacity
250 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi
AC 230 V (50/60Hz)
39.9 cm x 43.65 cm x 32.95 cm
15.3 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel, EPEAT Silver
Copier Type
Digital
Printing Technology
Ink-jet - colour
PC Connection
USB 2.0, LAN, Wi-Fi
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Preset Enlargements
141%, 200%, 100%
Preset Reductions
50%, 71%, 93%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
Ricoh GelJet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 6, PCL 5c, Ricoh RPCS
Automatic Duplexing
First Print Out Time B/W
5.5 sec
First Print Out Time Colour
6.5 sec
Scanning
Optical Resolution
1200 x 1200 dpi
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
250 sheets
Max Media Capacity
850 sheets
100 sheets
Speed Details
Copying: up to 29 ppm - B/W , Copying: up to 29 ppm - colour , Printing: up to 29 ppm - B/W , Printing: up to 29 ppm - colour
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.5 or later
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
45 Watt
Power Consumption Standby
3.1 Watt
Warm Up Time
35 sec
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Blue Angel Compliant
39.9 cm
43.65 cm
32.95 cm
15.3 kg
Scroll to top
