BT.com
Wishlist
Ricoh A4 Mono Laser Printer 40ppm Mono
Ricoh A4 Mono Laser Printer 40ppm...
£431.82
Hurry, only 1 left in stock!
£431.82
Add to wishlist
Delivery
Standard 1-3 working days
As new projects and challenges emerge, you differentiate yourself by stepping up, staying on task and meeting the tightest deadlines. But sometimes, even the hardest-working employee needs a little help. Ricoh understands.
After all, Ricoh has built a legacy of helping hard-working people move information and ideas effortlessly - with innovations like the Ricoh SP 4510DN. Print a wide range of high-quality black-and-white documents at high speeds and move on to the next project quickly. You'll be saving more than time. You can fit the compact, feature-rich printer into virtually any workflow, workgroup - and budget.
Ricoh SP 4510DN - printer - monochrome - LED
Printer Type
Workgroup printer - LED - monochrome
14 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
RAM Installed (Max)
512 MB (1536 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF
Media Type
Plain paper, recycled paper, thick paper, thin paper, preprinted paper
Total Media Capacity
250 sheets
Monthly Duty Cycle (max)
150000 pages
Print server
Printer Features
Print from mobile device
AC 230V
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Microsoft Certification
Compatible with Windows 7
37 cm x 39.2 cm x 30.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5 sec
Language Simulation
Fonts Included
45 x PCL , 136 x PostScript 3 , 13 x Intellifonts
Printer Features
RAM
RAM Installed (Max)
512 MB / 1536 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
52 g/m² - 162 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
Max Media Capacity
1600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
150000 pages
Print server
Security Protocols & Features
LDAP, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1110 Watt
Environmental Standards
ENERGY STAR
37 cm
39.2 cm
30.6 cm
14 kg
Scroll to top
