BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
RCF Over Head Speaker For False Ceiling Installation
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
The PL6X is a ceiling speakers featuring elegant and innovative design that can be flush-mounted in false ceilings or panels.
- Incorporating a 160 mm (6") loudspeaker.
- Both have a coaxial 25 mm (1") tweeter placed on a bridge support.
- The speakers are equipped with a line transformer that enables direct connection to constant voltage systems at 70V or 100V.
- The multiple sockets on the transformer make it possible to select the output power from among several values.
- Installation is quick and easy thanks to a special three-hook system that avoids the need for using screws and pallet or other attachment elements.
Scroll to top
