BT.com
Wishlist
Razer Tiamat 2.2 Gaming Headset
Delivery
Standard Due date unavailable
Epic Sound, Epic Bass
Optimized positional audio
The audio drivers in the Razer Tiamat 2.2 have been designed to simulate a three-dimensional audio effect for deeper immersion with your games. Get a sense of position and depth in your surroundings, so you can hear how far and where exactly an opponent is by his gunfire or footsteps, for the tactical advantage.
Two discrete subwoofer drivers for heavier-duty bass
The Razer Tiamat 2.2 houses not one, but two sub-woofer drivers for stronger bass support and overall audio performance so you are closer to the action and further from thin, mediocre basslines.
Maximum comfort, maximum durability
The Razer Tiamat 2.2's sturdy construction and snug-fit padded leatherette ear cups ensure extended headset life and ultimate comfort so you can keep terrorizing noobs during those hardcore marathon gaming sessions.
Razer Tiamat 2.2 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 109 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Microphone on/mute
Headset
Recommended Use
Computer
Headphones
Circumaural
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
109 dB
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
Microphone
Boom
Uni-directional
Wired
Sensitivity
-36 dB
Frequency Response
50 - 16000 Hz
Signal-To-Noise Ratio
50 dB
Remote Control
Controls
Microphone on/mute
Connector Type
Headset (mini-phone stereo 3.5 mm)
Headphones cable
Scroll to top
