Click to visit BT.com
BT.com
Wishlist
Razer Manticor Elite Aluminium Gaming Mouse Mat
Quicklinx: 8FTBWS00
Mfr#: RZ02-00920100-R3M1
FEATURES
Robust Aluminum Unibody
The Razer Manticor is constructed from a single sheet of aircraft-grade aluminum, stamped flatter and smoother for an unhindered glide. At the same time, the molecular rebonding from the machining process creates a highly rigid structure for maximum durability. It is then sand-blasted for a texture that further aids tracking precision and provides a great feel under your hand as you swipe.
Optimized Tracking Surface
The Razer Manticor's entire surface has a lab-developed microscopic texture that delivers the most consistently accurate sensor readings. There are no in-game jitters or interrupted tracking problems when using this mat.
Its finish was specifically chosen during extensive testing as the best for sensor reflectivity. What you get is the rapid responsiveness to meet challenges head-on and effortlessly land every headshot.
Thinner, Wider Profile
The Razer Manticor has been cut thinner for a slimmer profile that almost melds to your desk. This ensures a continuous swiping experience even if your mouse were to travel off the generously expansive surface of your mouse mat. It is also ergonomically more comfortable, minimizing wrist strain so you can keep winning in games for longer.
TECH SPECS
  • Ultra-smooth, sandblasted surface
  • Robust aluminum unibody
  • Thinner, wider profile
  • Non-slip rubber base
  • Product dimensions:
    Width: 255 mm / 10.04" Length: 355 mm / 13.98" Height: 2.2 mm / 0.09"
  • Approximate Weight: 373 g / 0.82lbs
Razer Manticor Elite Gaming Mouse Mat - mouse pad
Mouse pad
Product Material
Aluminium, rubber
25.5 cm x 35.5 cm
373 g
6 months warranty
Mouse pad
Product Material
Aluminium, rubber
25.5 cm
35.5 cm
Thickness
0.22 cm
373 g
Non-slip, Ultra-Smooth Sandblasted Surface
6 months warranty
Service & Support Details
Limited warranty - 6 months
