Click to visit BT.com
BT.com
Wishlist
Razer Mamba Elite 4G 2012 Gaming Mouse - laser / optical - 7 button(s) - wireless/wired
Quicklinx: 81NVWS00
Mfr#: RZ01-00120400-R3G1
The Razer Mamba 2012 returns with an ultra-precise 4G Dual Sensor System, that makes use of both a laser and an optical sensor to enhance tracking precision by calibrating to different surfaces and allowing adjustment of liftoff tracking distance. With an improved battery life for more untethered gaming enjoyment, a multicolored LED for personalization, and outfitted with an industry-leading gaming grade wireless technology, the Razer Mamba is still in a league of its own.
Gaming Grade Wireless Technology
Unrivalled gaming grade wireless technology means the Razer Mamba performs as well cordless as it does corded, giving you utter freedom of motion whilst you win gloriously in games. With a 1ms response rate, your command gets executed first even if you and your opponent react at the same time.
Experience a new standard of gaming precision with the 6400dpi 4G Dual Sensor System, outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. The Razer Mamba can not only match the speed of your swipes, but also allows configuration of cutoff distance to manage liftoff tracking, empowering you with more control than ever, no matter the play style.
Improved Battery Life and Charging Dock
The Razer Mamba has 15% more battery life than its predecessor, letting you game unwired for longer. When you need to recharge, just pop it on the sleek charging dock which also acts as the wireless receiver unit.
Multi-Color Lighting
With the new multicolored LED that has over 16 million colors, customize the Razer Mamba to suit your personal style or mood. This is your gaming weapon and yours alone.
Razer Mamba 2012 - mouse - USB, 2.4 GHz
Mouse
Wireless, wired - USB, 2.4 GHz
7 cm x 12.8 cm x 4.3 cm
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
6400 dpi
Performance
50 G maximum acceleration, 1 ms response time
Programmable buttons, scrolling wheel, multicolour LEDs, 4G Dual Sensor System
1 x USB cable - external
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
2 years warranty
Mouse
Wireless Receiver
7 cm
12.8 cm
4.3 cm
Input Device
Wireless, wired
USB, 2.4 GHz
Laser
Buttons Qty
7
Movement Resolution
6400 dpi
Performance
1 x USB - 4 pin USB Type A
Run Time (Up To)
16 hour(s)
Additional Requirements
CD-ROM
System Requirements Details
HD 35 MB
2 years warranty
Service & Support Details
Limited warranty - 2 years , Limited warranty - battery - 6 months
