BT.com
Wishlist
Razer Deathstalker Expert Gaming Keyboard
Delivery
Standard Due date unavailable
More Control, More Win
The Razer DeathStalker gaming keyboard delivers merciless power when it is designed with slim keycaps for shorter travel distance and rapid-fire actuations. Your fingers will be flying across the low-profile keys at lightning speed and in comfort, executing commands for your master plan faster than enemies can react.
Unlike traditional keyboards that can only register up to 3 simultaneous key presses, the superior anti-ghosting technology built into the Razer DeathStalker allows up to ten simultaneous key presses to obliterate the competition more effortlessly. Every key actuated at the same time will respond accurately in-game with zero lag.
Fire up your lightning fast reflexes and competitive instincts with a fully back-lit gaming keyboard designed for blazing fast actuations, empowering you to unleash as many commands and macros as there are fingers on both your hands. Give no quarter with the Razer DeathStalker.
Fully programmable slim chiclet keycaps
The slim 2mm chiclet keycaps on the Razer DeathStalker ensure less time is needed to actuate each key so you can react faster to situations and enemies. Your fingers can move quickly between the keys, ensuring your entire master plan for gaming domination is executed instantly.
10 Key Rollover in gaming mode
Actuate as many keys as you have fingers, and have all of them register accurately and quickly in-game. With the Razer DeathStalker's anti-ghosting capabilities, you can deliver overwhelming destruction to your opponents, and ensure that every command is registered and executed perfectly.
Razer Synapse 2.0
Razer Synapse 2.0 is cutting-edge, intuitive software that functions as the Razer DeathStalker's brain, automatically syncing the gaming keyboard to a cloud server to download driver and firmware updates, while saving your individual settings. Sync your custom settings and macros automatically with this unified configurator, allowing customization of all your Razer products with a single login.
TECH SPECS
Chiclet style key caps
Green LED Backlit keys
1000Hz Ultrapolling
Fully programmable keys with on the fly macro recording
Razer Synapse 2.0 enabled
Dedicated Gaming mode
Anti-ghosting capability for up to 10 simultaneous key presses
Fixed wrist rest
Razer DeathStalker Expert - keyboard - UK
Keyboard
USB
Layout
Hot Keys Function
Programmable
Anti-ghosting, built-in wrist rest, On-The-Fly macro recording, braided cable, 10-key rollover, green backlighting, 1000Hz Ultrapolling, Gaming Mode
Keyboard
USB
Input Device
Hot Keys Function
Programmable
Layout
Included Software
Razer Synapse 2.0
Microsoft Windows Vista / XP / 7
Scroll to top
