BT.com
Wishlist
Razer Chimaera 5.1 - Wireless Gaming Headset ( ear-cup )
Delivery
Standard Due date unavailable
The Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 gives you a true-to-life surround sound experience. Building on Razer's extensive gaming audio expertise from PC gaming, this wireless headset offers pinpoint tournament grade 5.1 positional audio with extra large circumaural ear cups for maximum comfort.
The base station doubles up as a charging dock and audio processing unit, giving you the option to adjust the game sound and link up to four base stations to talk to your teammates over a lag-free, local communication channel.
5.1 Channel Dolby® Surround Sound for Pinpoint Positional Audio
Offering the full range of surround sound, with drivers tuned for 3D positional audio the Razer Chimaera 5.1 Wireless Gaming Headset for Xbox 360 will allow you to anticipate your enemies' every step and hear the true game sound in full detail.
5.8 GHz Frequency Headset for Interference-free Wireless Performance
The Razer Chimaera 5.1 allows a true wireless Xbox experience for up to 8 hours with no cables restricting your movement. Using the 5.8 GHz frequency protects this headset against almost all wireless interferences.
Dedicated Lag-free Local Team Communications
Up to four Razer Chimaera 5.1 base stations can be connected to create a lag-free, crystal clear voice channel for dedicated team conversations.
Razer Chimaera 5.1 - headset
Headset - wireless - 5.8 GHz
Recommended Use
Game console, computer
Headphones Form Factor
Full size
Wireless - 5.8 GHz radio frequency
Sound Output Mode
5.1 channel surround
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Controls
Volume, microphone on/mute
Headset - 5.8 GHz
Recommended Use
Max Operating Distance
10 m
Headphones
Circumaural
Available Microphone
Sound Output Mode
Frequency Response
20 - 20000 Hz
Sensitivity
105 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Uni-directional
Sensitivity
-42 dB
Frequency Response
130 - 10000 Hz
Signal-To-Noise Ratio
55 dB
Remote Control
Controls
Wireless Link
Transmission Range
10 m
Base station
2 AAA type
Run Time (Up To)
8 hour(s)
Resources
The following resources are available for the Razer Chimaera 5.1 - Wireless Gaming Headset ( ear-cup )
Scroll to top
