Click to visit BT.com
BT.com
Wishlist
Razer BlackWidow 2013 Expert Mechanical Keyboard
Quicklinx: 8CCCWS00
Mfr#: RZ03-00391900-R3W1
Full Mechanical Keys for Superior Tactility and Faster Response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimized actuation force of 50g and a reduced actuation distance of 2 mm the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard.
10 key roll-over in gaming mode
Actuate as many keys as there are fingers on both your hands and have them all register accurately and quickly during gaming. With the Razer BlackWidow's gaming mode 10 key roll-over, you can deliver overwhelming destruction on your opponents, or just ensure every command is executed perfectly for victorious gaming.
Razer Synapse 2.0
Razer Synapse 2.0 is cutting-edge intuitive proprietary software that functions as the Razer BlackWidow's brain - automatically syncing the keyboard to a cloud server to download driver and firmware updates, as well as save individual gamer settings like keybinds and macros without you needing to lift a finger
TECH SPECS
Full mechanical keys with 50g actuation force
1000Hz Ultrapolling
Fully programmable keys with on-the-fly macro recording
10 key rollover anti-ghosting
Razer Synapse 2.0 enabled
Gaming mode option
5 additional dedicated macro keys
Audio-out/mic-in jacks
USB passthrough
Braided fiber cable
Approximate Size : 475 mm / 18.72" (Length) x 171 mm / 6.74" (Width) x 20 mm / 0.79" (Height)
Approximate Weight : 1500 g / 3.31 lbs
Razer BlackWidow 2013 - keyboard
Keyboard
USB
Hot Keys Qty
5
Hot Keys Function
Programmable, macros buttons
Integrated USB Hub, anti-ghosting, On-The-Fly macro recording, braided cable, 10-key rollover
47.5 cm x 17.1 cm x 2 cm
1.5 kg
1 year warranty
Keyboard
USB
Input Device
Hot Keys Qty
5
Hot Keys Function
Keyboard Technology
Mechanical
47.5 cm
17.1 cm
2 cm
1.5 kg
Headphone output , Microphone input
1 x USB cable
Included Software
Razer Synapse 2.0
Microsoft Windows Vista / XP / 7
1 year warranty
Service & Support Details
Limited warranty - 1 year
