BT.com
Wishlist
Quantum SuperLoader 3, one LTO-4HH tape drive, Model B, 16 s
Delivery
Standard Due date unavailable
Designed for simple and reliable backups, the SuperLoader 3 offers an exclusive package of advanced features including StorageCare Guardian, remote management, and barcode reader - all at no additional cost. It also gives you the widest range of drive options in the industry to support data requirements up to 100TB - with the flexibility to expand as your storage needs grow.
The SuperLoader 3 brings you a full suite of advanced features at an affordable price with easy integration, an intuitive user interface, and compatibility with a broad range of backup software packages. And because you can easily expand from 8 to 16 cartridge slots, your investment is protected as your needs grow. In addition, the SuperLoader 3 packs up to 40TB of native capacity and 100TB of compressed data into a 2U rackmount form factor.
Quantum SuperLoader 3 - tape autoloader - LTO Ultrium - SCSI
Tape autoloader
Recording Standard
LTO Ultrium 4
Enclosure Type
Rack-mountable - 2U
Interface Type
SCSI LVD
Total Storage Capacity
12.8 TB (native) / 25.6 TB (compressed)
Removable Media Capacity
16
Supported Tape Drives
LTO Ultrium 4
Key Features
Barcode reader
42.4 cm x 69.9 cm x 8.7 cm
14.1 kg
EMEA
Storage Removable
LTO Ultrium
Storage Removable Capacity
800 GB (native) / 1.6 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 3, Ultrium 4
Data Transfer Rate (native)
80 MBps (288 GBph)
Data Transfer Rate (compressed)
160 MBps (576 GBph)
3 years warranty
Tape autoloader - LTO Ultrium
Recording Standard
LTO Ultrium 4
Enclosure Type
Rack-mountable - 2U
Interface Type
SCSI LVD
16
LTO Ultrium 4
Key Features
Barcode reader
Built-in Devices
Display
42.4 cm
69.9 cm
8.7 cm
14.1 kg
EMEA
Storage Removable
LTO Ultrium
Recording Standard
80 MBps (288 GBph)
160 MBps (576 GBph)
1 x Ultra320 SCSI LVD (input) - 68 pin HD D-Sub (HD-68) , 1 x Ultra320 SCSI LVD (output) - 68 pin HD D-Sub (HD-68) , 1 x Ethernet 10Base-T/100Base-TX (management) - RJ-45
5 barcode labels for cleaning cartridges, 30 barcode labels
1 x SCSI terminator , 1 x SCSI cable - 2 m , 1 x network cable - 3.1 m
Rack Mounting Kit
Included
CSA, UL, VCCI, C-Tick, VCCI Class B ITE, BSMI CNS 13438 Class A, EN 60950, EN55022, ICES-003, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 3548, FCC, FCC CFR47 Part 15 B
Power supply
Limited warranty - parts - 3 years - shipment - response time: 2 business days
10 °C
35 °C
20 - 80%
Scroll to top
