BT.com
Wishlist
Quantum  SuperLoader 3 One LTO-6HH Tape Drive Eight Slots  6Gb/s
Quantum SuperLoader 3 One LTO-6HH...
£2,555.14
Hurry, only 2 left in stock!
£2,555.14
Add to wishlist
Delivery
Standard 1-3 working days
Designed for simple and reliable backups, the SuperLoader 3 offers an exclusive package of advanced features including StorageCare Guardian, remote management, and barcode reader - all at no additional cost. It also gives you the widest range of drive options in the industry to support data requirements up to 100TB - with the flexibility to expand as your storage needs grow.
The SuperLoader 3 brings you a full suite of advanced features at an affordable price with easy integration, an intuitive user interface, and compatibility with a broad range of backup software packages. And because you can easily expand from 8 to 16 cartridge slots, your investment is protected as your needs grow. In addition, the SuperLoader 3 packs up to 40TB of native capacity and 100TB of compressed data into a 2U rackmount form factor.
Quantum SuperLoader 3 - tape autoloader - LTO Ultrium - SAS-2
Tape autoloader
Recording Standard
LTO Ultrium 6
Enclosure Type
Rack-mountable - 2U
Interface Type
SAS-2
Total Storage Capacity
20 TB (native) / 50 TB (compressed)
Removable Media Capacity
8
Supported Tape Drives
LTO Ultrium 6
Key Features
Barcode reader, with 1 mail slot
42.42 cm x 69.85 cm x 8.66 cm
14.06 kg
EMEA
Storage Removable
LTO Ultrium
Storage Removable Capacity
2.5 TB (native) / 6.25 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 6, Ultrium 5
Data Transfer Rate (native)
160 MBps (576 GBph)
Data Transfer Rate (compressed)
400 MBps (1.44 TBph)
3 years warranty
Tape autoloader - LTO Ultrium
Recording Standard
LTO Ultrium 6
Enclosure Type
Rack-mountable - 2U
Interface Type
SAS-2
8
LTO Ultrium 6
Key Features
Built-in Devices
Display, remote management adapter
42.42 cm
69.85 cm
8.66 cm
14.06 kg
EMEA
Storage Removable
LTO Ultrium
Recording Standard
Ultrium 5, Ultrium 6
160 MBps (576 GBph)
1 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 1 x Ethernet 100Base-TX (management) - RJ-45
5 barcode labels for cleaning cartridges, 30 barcode labels
1 x SAS cable - 2 m , 1 x network cable - 3.1 m
Rack Mounting Kit
Included
MSBF
1,500,000
FCC Class B certified, CSA, UL, VCCI, C-Tick, BSMI CNS 13438 Class A, EN 60950, EN55022, ICES-003, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, AS/NZS 3548, FCC, RoHS, WEEE, FCC CFR47 Part 15 B, EMI, Directive 2002/96/EC, Directive 2002/95/EC, VCCI Class B
Power supply
Limited warranty - parts - 3 years - shipment - response time: 2 business days , Technical support - phone consulting - 3 years - availability: 9 hours a day / Monday-Friday
10 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
