BT.com
Wishlist
Qsan Technology V100-P10-C424 24 bay 4U SAN
Qsan Technology V100-P10-C424 24...
£3,249.46
£3,249.46
Add to wishlist
Delivery
Standard Due date unavailable
AegisSAN V100 is the SAN storage series designed for surveillance and backup applications to deliver ultra performance.
Qsan AegisSAN V100-P10 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 4U
iSCSI (1 GbE)
24 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
1 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
44.6 cm x 54.97 cm x 17.6 cm
34 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 4U
Chassis
Supported Devices / Modules Qty
24
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
iSCSI (1 GbE)
Storage Controller
1 x RAID
Interface Type
Cache / Buffer Size (Max)
4 GB
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD
Expansion Bays
24 (total) / 24 (free) x hot-swap
6 x Ethernet 1000 , 1 x management - RJ-45
Wake on LAN, Power Factor Correction (PFC), built-in 3 cooling fans, e-mail notification, web management, hot-swappable fans
C-Tick, BSMI, CB, FCC, RoHS, 80 PLUS Gold, LVD
2 x internal power supply
Max Supported Qty
2
Power Provided
550 Watt
44.6 cm
54.97 cm
17.6 cm
34 kg
Limited warranty - 3 years
5 - 95% (non-condensing)
Scroll to top
