BT.com
Wishlist
Qsan Technology V100-P10-C316 16 bay 3U SAN
Qsan Technology V100-P10-C316 16...
£2,533.99
£2,533.99
Add to wishlist
Delivery
Standard Due date unavailable
AegisSAN V100 is the SAN storage series designed for surveillance and backup applications to deliver ultra performance.
Qsan AegisSAN V100-P10 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI (1 GbE)
Host Channels
6
Maximum LUNs
2048
0 (installed) / 16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
1 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
No HDD
AC 120/230 V
Power Redundancy
44.6 cm x 54.97 cm x 13 cm
30 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
0
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
iSCSI (1 GbE)
Host Channels
6
Maximum LUNs
2048
RAM
Installed Size
4 GB
Storage Controller
1 x RAID
Interface Type
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
6 x Ethernet 1000 , 1 x management
Power Factor Correction (PFC), built-in 3 cooling fans
C-Tick, BSMI, CB, FCC, RoHS, 80 PLUS Gold, LVD
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
44.6 cm
54.97 cm
13 cm
30 kg
Limited warranty - 3 years
5 - 95% (non-condensing)
Scroll to top
