BT.com
Wishlist
Qsan Technology U221 12 Bay 24TB RE 2u ZFS NAS
Delivery
Standard Due date unavailable
TrioNAS U221 features enterprise-class DeDup eliminating duplicate copies of redundant data so as to save storage capacity significantly, and thereby SMBs can optimize storage space utilization and save costs greatly. Plus compression feature to encode information using fewer bits than original representation, storage capacity can be saved up to 90%.
TrioNAS U221 is equipped with 80 PLUS Platinum power supplies to enhance energy efficiency for power savings, peak reduction and improved power quality. In addition, TrioNAS features thin provisioning to allocate disk storage space in a flexible manner based on the minimum space required. With all the green designs, TrioNAS U221 helps organizations to save resources and money.
TrioNAS U221 is designed to addresses the explosion of unstructured data and files, where reads/writes are random, by treating random writes as sequential blocks. To provide better file data sharing, the ZFS-based storage system supports SMB v2.0, NFS v3/v4, AFP v3.3, FTP and SFTP, WebDAV, and iSCSI CHAP. In addition, TrioNAS U221 offers very easy-to-use management tools including QCentral, SNMP trap, performance states, and start-up wizard and so on. All these functions allow SMBs and work groups to manage TrioNAS U221 at minimum efforts and greatly enhance the efficiency in the working environment.
TrioNAS U221 adopts Intel Xeon E3 CPU to provide high availability and performance. At the same price, TrioNASU 221 provide more superb enterprise-level features; providing the same feature, TrioNASU 221 offers the best values to customers.
Integration NAS and iSCSI SAN, TrioNAS U221 unified architecture help customers to solve many data management problems with a single system, making complex and fast growing storage needs much more manageable and affordable.
Qsan TrioNAS U221 - NAS server - 24 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
24 TB
12 (installed) / 12 (max)
44.2 cm x 71.12 cm x 8.8 cm
1 x Intel Xeon
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, 60
Hard Drive
12 x 2 TB SATA 6Gb/s
Network adapter 10Mb LAN, 100Mb LAN, GigE, 10 GigE
Power Redundancy
SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
3 years warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
24 TB
44.2 cm
71.12 cm
8.8 cm
Processor / Memory
Processors Installed
1 x Intel Xeon
Max Supported Qty
1
RAM Installed
32 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
HDD - hot-swap
12 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Network adapter
Network / Transport Protocol
NTP, iSCSI, FTP, DHCP
Remote Management Protocol
SNMP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
DHCP support, trunking, LDAP support, VLAN support, wake on LAN (WOL), antivirus analysis, Jumbo Frames support
Encryption Algorithm
SSL, TLS
IEEE 802.3ad (LACP)
Expansion Bays
12 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb
UL, BSMI, cUL, CB, FCC, RoHS
X internal power supply
Installed Qty
2
Power Redundancy
Power Provided
549 Watt
Limited warranty - 3 years
5 - 95% (non-condensing)
Scroll to top
