BT.com
Wishlist
Qsan Technology U120 iSCSI 1U 4 Bay Trio NAS
Qsan Technology U120 iSCSI 1U 4 Bay...
£800.61
£800.61
Add to wishlist
Delivery
Standard Due date unavailable
TrioNAS consolidates NAS and IP-based iSCSI SAN in one box. Unified storage can help consolidate your IT infrastructure and reduce hardware expenses. You don't need multiple file servers for SMB, NFS, AFP, FTP, and WebDAV. TrioNAS supports all these protocols in one box including iSCSI. TrioNAS will be your common storage pool that is accessible at either file or block level over existing IP networks. It's a cost-effective and efficient storage solution.
Qsan TrioNAS U120 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
0 GB
0 (installed) / 4 (max)
44.2 cm x 43.18 cm x 4.4 cm
1 x Intel Atom D2550
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 10
10Mb LAN, 100Mb LAN, GigE
Power Redundancy
Apple MacOS X, Red Hat Linux 5.x, Microsoft Windows, Red Hat Linux 6.x, Oracle Solaris
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
0 GB
44.2 cm
43.18 cm
4.4 cm
Processor / Memory
Processors Installed
RAM Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Network / Transport Protocol
NTP, iSCSI, FTP, DHCP
Remote Management Protocol
SNMP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, VLAN support, wake on LAN (WOL), firmware upgradable, Jumbo Frames support, teaming support, LACP support, e-mail notification, cloud backup
Encryption Algorithm
SSL, TLS
Expansion Bays
4 (total) / 4 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45
Wake on LAN, Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, CB, FCC, RoHS
X internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
226 Watt
Limited warranty - 3 years
5 - 95% (non-condensing)
Other bundles
£800.61
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.27
£803.88
Scroll to top
