BT.com
Wishlist
Qsan Technology Q500-P20-S212
Delivery
Standard Due date unavailable
AegisSAN Q500-P20 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
Qsan AegisSAN Q500-P20 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
iSCSI (1 GbE), iSCSI (10 GbE)
12 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
0 no HDD
Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11, Microsoft Windows Server 2012, Microsoft Windows XP / 7
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 8.8 cm
25 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Storage Controller
RAID
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 8 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD
0
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
2 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000 , 1 x management
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS, 80 PLUS Gold
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
44.6 cm
49.95 cm
8.8 cm
25 kg
Limited warranty - 3 years , Limited warranty - battery - 1 year
5 - 95% (non-condensing)
Scroll to top
