BT.com
Wishlist
Qsan Technology Q500-P10-D212 iSCSI 12 Bay SAN
Delivery
Standard Due date unavailable
AegisSAN Q500-P10 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
AegisSAN Q500-P10 features six 1GbE iSCSI ports and one 1GbE management port to provide high availability & great performance for enterprises and SMB.
Qsan AegisSAN Q500-P10-D212 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
36 TB
iSCSI (1 GbE)
12 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
12 x 3 TB HDD - hot-swap
SunSoft Solaris 10, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012, SunSoft Solaris 11, Microsoft Windows XP / 7
AC 120/230 V - 50/60 Hz
Power Redundancy
44.6 cm x 49.95 cm x 8.8 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
36 TB
HDD Array External Interface
iSCSI (1 GbE)
Storage Controller
2 x RAID (iSCSI)
Interface Type
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
8 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
HDD - hot-swap
12 x 3 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap
12 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 1000Base-T (management) - RJ-45
Power Factor Correction (PFC), built-in 2 cooling fans, hot-swappable fans
UL, BSMI, cUL, FCC, RoHS, 80 PLUS
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
400 Watt
44.6 cm
49.95 cm
8.8 cm
Limited warranty - 3 years , Limited warranty - battery - 1 year
5 - 95% (non-condensing)
Scroll to top
