BT.com
Wishlist
Qsan Technology P400Q-D212 12 Bay 2u 12pt iSCSI
Qsan Technology P400Q-D212 12 Bay...
£6,412.70
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
£6,412.70
Add to wishlist
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
QSAN P400Q-D212 12 Port 1GbE iSCSI-SAS 2U Rackmount SAN System
Key Features
-RAID Controller - Dual controllers
-No. of Host Channels Per Controller - 6 x 1GbE iSCSI ports
-Expansion Enclosure - J300Q series
-Cache Memory Per Controller - 4GB, up to 8GB
-No. of Hard Drives (6G, 3G SAS, 6G, 3G SATA) - 12
Provide Great Performance & Efficiency for Mid-range Enterprise
AegisSAN LX P400Q, boasting Intel Xeon processors, is a 1GbE iSCSI, 6G SAS high availability RAID system offering high performance and supporting up to 192 drives. AegisSAN LX P400Q storage includes QiSOE (Qsan Hardware iSCSI offload engine) plus QReplica for remote replication. It provides hardware RAID function and superior performance to process tremendously huge amount of random access data.
1.Fully redundant & hot pluggable designs: RAID controllers, power supplies, fan modules, battery backup modules, & JBOD expansion
2.Six (6) iSCSI ports per controller
3.Hardware iSCSI offloaded engine
4.Green storage designs: auto disk spin down, advanced cooling mechanism, & 80 PLUS energy-efficient power supplies
5.Advanced data protection: RAID 6, 60, QSnap writeable snapshot, Windows VSS support, QReplica remote replication, Volume cloning
6.Flexible volume management for multiple applications & environments: virtualization (VMWare, Hyper-V, Citrix), cloud storage, SQL, Exchange, surveillance, file backup, email, boot from SAN, & etc
7.High connection availability: load balancing & failover
8.Extendable capacity up to 192 hard drives
High Availability
P400Q iSCSI system is specially designed for high availability applications. The P400Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, volume cloning, QReplica remote replication, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, P400Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly.
Default Built-In Data Protection Features
The P400Q systems are built-in with Qsan's highly reliable data protection features, from writeable snapshot, volume cloning, to remote replication. Your valuable data can be easily safeguarded and synchronized locally and remotely. In case of accidents, data corruption, virus, and even disasters, the services and applications can be recovered in a very short time.
Outstanding Performance
Applications
The optimized IOPS and throughput are capable of providing run-time critical online services, such as Cloud storage, SQL, Exchange, and high-end surveillance storages. Furthermore, with the iSCSI interface, P400Q is ideal for virtualization environments - VMWare, Hyper-V, and Citrix. Users can install up to 128 OSes in the iSCSI system through the Boot-from-SAN feature. With this feature, the multiple OSes/Servers can be managed easily and well protected by Qsan's advanced data protection features, and there will be no system downtime caused by single point of failure.
Green
All P400Q system has Qsan's default power saving feature. In most cases, the hard drives consume most power. With the auto disk spin down feature and proper configuration, the power consumption of hard drives can be reduced to a minimum, and users will not even notice this feature. P400Q monitors the environment temperature for cooling mechanism and the fan modules respond accordingly. The power supply modules are all 80 PLUS power efficient for better power converting rate. In virtue of the reduction of hard drive power consumption, the advanced cooling mechanism, and the energy-efficient power supplies, we can use energy more efficiently and reduce unnecessary carbon footprint.
Scroll to top
