BT.com
Wishlist
Qsan Technology 16 Bay Q500-P21-S316 10GbE Cat6
Qsan Technology 16 Bay...
£4,640.35
£4,640.35
Add to wishlist
Delivery
Standard Due date unavailable
AegisSAN Q500-P21 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
Qsan AegisSAN Q500-P21 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI (1 GbE), iSCSI (10 GbE)
16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
1 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
No HDD
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 13 cm
33 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Storage Controller
1 x RAID
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 8 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
2 x Ethernet 10Gb - RJ-45 , 2 x Ethernet 1000 , 1 x management
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS, 80 PLUS Gold
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
44.6 cm
49.95 cm
13 cm
33 kg
Limited warranty - 3 years , Limited warranty - battery - 1 year
5 - 95% (non-condensing)
Scroll to top
