Click to visit BT.com
BT.com
Wishlist
Qpad QH-1339 Pro Gaming Headset
Quicklinx: 8B6DWS00
Mfr#: QH-1339
QPAD QH-1339 Pro Gaming Headset
Play like you never heard before
The QH-1339 headset was created jointly with beyerdynamic. The closed construction absorbs external sounds by approximately 18 decibels (dBA), which makes the immaculate reproduction of sound possible even in loud environments and turbulent LAN parties; you can now hear even the smallest details in the game that you have never been able to hear before.
The deep bass allow explosions in video games to detonate so realistically that you are almost swept out of your chair. The frequency response goes from an impressive 5Hz - 30KHz equivalent to a professional studio headphone.
"We at QPAD feel privileged and excited that we have been given the opportunity of teaming up with one of the world's absolute leading developers of professional headphones as beyerdynamic truly is," says Thomas Gallus Jensen, Sales Director of QPAD. And he adds: "We are confident that the QH-1339 headset will be at the top of every gamers' wish list, as it is nothing but first class in every aspect. This is also why we dare to give out a 5-year warranty on it".
The QH-1339 is technologically based on a pilot headset developed for private aviation. Computer gamers also profit from the robust construction and the precision of the audio transmission. Both pilots and gamers must have lightning fast reactions that leave no time for hesitation about the correctness of a decision.
The enclosed USB adapter fully replaces the sound card in the PC and does not only provide maximum sound quality; it also makes the operation matchlessly simple. In addition, all of the headset parameters, such as the microphone sensitivity, can also be set using the driver software. Just remove the USB adapter and the QH-1339 headset fits every standard audio device with its mini-jack plug - a portable music player, for example, or the stereo system in the living room. Here as well, the QH-1339 gives it's listener the feeling of being there live at all times.
The professional condenser microphone also meets the very highest demands. It reliably eliminates noise interference and only allows the intended sound to pass to your counterpart. In doing so, the sound quality is so good that the microphone capsule, technically speaking, is even suitable for recording music.
- Duarble metal construction - 5 Year warranty
- Hand crafted in Germany by famous Beyerdynamic
- Superior Hi Fi sound 5-30.000hz
- Superior studio-quality microphone
QPAD QH-1339 Professional Gaming Headset - headset
Headset - wired
Recommended Use
Game console, computer
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 5 - 30000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Technology
Electret condenser
Microphone Operation Mode
Mono
5 years warranty
Headset
30 cm
16 cm
76 cm
380 g
Recommended Use
Headphones
Circumaural
Dynamic
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
5 - 30000 Hz
Total Harmonic Distortion (THD)
0.2%
Sensitivity
96 dB
Impedance
32 Ohm
Microphone
Boom
Electret condenser
Mono
Wired
Impedance
1.5 kOhm
Microphone Power Source Voltage (DC)
9 V
Frequency Response
30 - 18000 Hz
0.2%
Max Sound Pressure
120 dB
Audio Input Details
Cardioid - 30 - 18000 Hz - Output Impedance 1.5 kOhm
Connector Type
Headphones ( mini-phone stereo 3.5 mm ) , Microphone ( mini-phone stereo 3.5 mm )
Headset cable - 2.5 m , USB adapter cable - 1.5 m
Headset USB digital audio converter
Plug and Play
5 years warranty
